Master List of How-To Guides for C7 Corvette Stingray
Old 06-19-2014, 12:21 AM
Theta
Theta's Avatar
St. Jude Donor '14-'15
Default Master List of How-To Guides for C7 Corvette Stingray
The following How-To Guides cover numerous topics and offer pictures, explanations, specifications, schematics, etc of how to work on your C7 Corvette Stingray.
These How-To Guides are neither endorsed by nor property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
Please continue to check back often, as this thread will continue to grow as more How-To Guides are added!
We hope you will find these guides useful.
Updated (2/28/15) - Major Overhaul, Added Sections/Dividers, Added Member How-To Guides Section
Updated (4/8/15) - Added Additional Member How-Tos
Updated (4/29/15) - Added Front/Rear Brake Rotor How-Tos
Updated (7/21/15) - Added Additional User-Submitted How-Tos / Cleaned-Up Some Older How-To Entries
Updated (8/26/15) - Added Additional User-Submitted How-Tos
_______________________________________
Specifications: Engine (6.2L LT1) Fastener Tightening / Torque Values
Specifications: Transmission (7-Speed Manual) Fastener Tightening / Torque Values
Specifications: Clutch (7-Speed Manual) Fastener Tightening / Torque Values
Specifications: Suspension (Front & Rear) Fastener Tightening / Torque Values
Specifications: Frame & Underbody Fastener Tightening / Torque Values
How-To: Lift/Jack The Vehicle Per GM Specifications
How-To: Bleed Brake System / Change Brake Fluid (Manual & Pressure) + Specs
How-To: Remove/Replace Front Brake Pads
How-To: Remove/Replace Rear Brake Pads
How-To: Remove/Replace Front Brake Calipers
How-To: Remove/Replace Rear Brake Calipers
How-To: Remove/Replace Front Brake Rotors
How-To: Remove/Replace Rear Brake Rotors
How-To: Replace Parking Brake Shoe, Electronic Emergency Brake Module + Schematics
How-To: Remove/Replace Exhaust Manifolds, Cats, X-Pipe / Prep for Header Install
How-To: Perform/Check Front/Rear Wheel Alignment
How-To: Remove/Replace Front Shock Absorbers
How-To: Remove/Replace Rear Shock Absorbers (with FE2,FE4)
How-To: Remove/Replace Rear Shock Absorbers (without FE2,FE4)
How-To: Remove/Replace Front Leaf Spring
How-To: Remove/Replace Rear Leaf Spring
How-To: Remove/Replace/Install Front Sway Bar
How-To: Remove/Replace/Install Rear Sway Bar
How-To: Bleed/Fill Rear Differential and Hydraulic System Service + Specs
How-To: Bleed Hydraulic Clutch System + Specs
How-To: Install Short Shifter / Replace Stock Shifter
How-To: Connect/Disconnect the Negative Battery Cable
How-To: Remove/Replace Vehicle Battery
How-To: Replace Front Headlamp HID Bulb
How-To: Adjust / Aim HID Headlamps
How-To: Drain/Fill Engine Oil & Replace Oil Filter (Dry Sump) + Specs
How-To: Drain/Fill Engine Oil & Replace Oil Filter (Wet Sump) + Specs
How-To: Drain/Fill Manual Transmission (All Models) + Specs
How-To: Remove/Replace Door Sill Trim Plate(s)
How-To: Remove/Replace the Instrument Panel Trim Pad (Passenger Dash)
How-To: Remove/Replace Left (Driver) Door Interior Trim Panel
How-To: Remove/Replace Right (Passenger) Door Interior Trim Panel
How-To: Remove/Replace Steering Wheel
How-To: Remove/Replace Rear Quarter Panel (Fender) - Driver's Side
How-To: Remove/Replace Rear Quarter Panel (Fender) - Passenger's Side
How-To: Remove/Replace Rear Quarter Panel Air Scoops
How-To: Remove/Replace Front Bumper Fascia
How-To: Remove/Replace Lower Rear Bumper Fascia
How-To: Remove/Replace Upper Rear Bumper Fascia
How-To: Remove/Replace the Outside Rearview Mirror
How-To: Remove/Replace the Outside Rearview Mirror Glass
How-To: Remove/Replace the Outside Rearview Mirror Inner Actuator
How-To: Remove/Replace Front/Side/Rear Emblems & Nameplate
How-To: Remove/Replace Front Wheelhouse Liner
How-To: Remove/Replace the Intake Manifold Covers
How-To: Remove/Replace Valve Rocker Arms & Pushrods
How-To: Remove/Inspect/Install the Cylinder Heads
How-To: Remove/Clean/Replace the Fuel Rail & Injectors
How-To: Remove/Replace Intake Manifold
How-To: Remove/Replace Spark Plugs / Plug Wires
How-To: Remove/Replace Front Center Speaker
How-To: Remove/Replace LEFT Upper Dash Tweeter
How-To: Remove/Replace RIGHT Upper Dash Tweeter
How-To: Remove/Replace Left (Driver) Upper and Lower Door Speakers
How-To: Remove/Replace Right (Passenger) Upper and Lower Door Speakers
How-To: Remove/Replace LEFT Rear Speakers
How-To: Remove/Replace RIGHT Rear Speakers
How-To: Remove/Replace Rear Subwoofer Assembly
How-To: Remove/Replace Speaker Amplifier
How-To: Identify Wiring To/From Audio Amplifier
NEW: Member-Written How-To Guides:
These guides have been selected from the countless threads here for being verified, helpful, and informative. All disclaimers above apply, and please note that these guides are neither monitored nor updated officially or unofficially by any staff or technical writers - they are the sole property and responsibility of the original author. If said author wishes to be removed from this list, please contact me via PM.
How-To: Add / Relocate Additional Windshield Washer Reservoir & Pump on Non-Z51 (Helpful for Meth)
How-To: Install Alky Control Meth Injection System for C7
How-To: Install/Upgrade to Z51 Brake System from Base C7
How-To: Install/Upgrade to Z51 Brake Ducts from Base C7
DIY: Painting Engine Bay Parts
How-To: Lower The Vehicle on Stock Bolts
How-To: Install Flex Fuel Sensor
How-To: Convert GT Seats to Competition Seats
How-To: Convert/Swap Upper Interior Panels to Sueded Microfiber
How-To: Remove Rear Fascia (with Pictures)
How-To: Remove Front Fascia / Front Bumper Cover (with Video & Pictures)
How-To: Self-Calibrate Stubborn TPMS Sensors
DIY: manual transmission and rear differential fluid service
[Mod] Switched AUX power jacks - making them always hot
Last edited by Zymurgy; 10-17-2022 at 10:23 AM. Reason: Added Always Hot AUX Power Jacks
The following 37 users liked this post by Theta:
!00%DISVET (03-01-2016), 1stVetteAW (09-12-2015), Ahmed_otb (11-26-2015), BarneyZ (01-27-2020), BenCasey (09-28-2015), bhk2 (05-27-2016), Bischof (10-24-2015), bosco1 (11-26-2019), CFD E59 (11-13-2022), ckirsch100 (09-03-2019), dariodelconte (10-10-2018), devnull (01-26-2018), FYREANT (11-03-2017), george vee (02-22-2018), hmshood (04-17-2016), Hopper12 (04-20-2018), Iceman2000 (04-12-2019), imxz28 (10-01-2015), JJoeG (12-20-2019), jtscherle (09-30-2023), Kendallw33 (11-11-2019), kenownr (10-18-2017), LB001 (01-05-2018), Master Yoda (05-08-2022), New driver (09-04-2023), pantera/diablo (09-27-2017), Pineapple (03-02-2018), Pizz (04-10-2018), Rebel Yell (03-16-2016), RichSobko (08-20-2017), Rwp315 (04-13-2016), snow (04-12-2017), SpunkyQ8 (02-23-2016), TB186 (01-24-2024), The Ur Quan (01-30-2021), tlippy (12-26-2016), X25 (05-23-2016) and 32 others liked this post. (Show less...)
Old 06-19-2014, 07:25 AM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Thank you for all your time and effort in creating the threads and taking the time to consolidate them in one thread.
Old 06-19-2014, 10:41 AM
$$$frumnuttin'
$$$frumnuttin''s Avatar
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Thanks for doing this Theta and Pewter99....the timing is great as we are seeing lots of folks digging into their cars with some fine mods.
Jerry
Old 06-23-2014, 10:17 AM
Road_runner
Road_runner's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Nice job
Could we ge a How-to on Harness Bars?
Old 06-23-2014, 02:46 PM
Theta
Theta's Avatar
At the moment, we don't have any specific installation information from any of the current vendors on their bar installation processes.
Once we do, and/or there are more bars on the market, I will be happy to add this information for you along with panel dis-assembly instructions.
Old 06-28-2014, 10:15 AM
pbrayton
pbrayton's Avatar
Default lowering on stock bolts
i know i saw a video of this but can't find it now even with search. does anyone have it?
Old 06-28-2014, 04:12 PM
1jester
1jester's Avatar
how do you check the dic codes on a c7?
Old 06-28-2014, 08:43 PM
Theta
Theta's Avatar
Are you referring to P-Codes?
Old 06-28-2014, 08:45 PM
Theta
Theta's Avatar
Added to the list. Here: http://forums.corvetteforum.com/c7-g...nd-photos.html
Old 07-02-2014, 03:58 PM
jspridge
jspridge's Avatar
Thanks for posting this information. Would you be able to add procedures for replacing the speakers in the doors and other interior panels?
Old 07-02-2014, 04:19 PM
Theta
Theta's Avatar
Absolutely - this is on my list, but I will bump it to the top for you. Expect the post later on today.
Old 07-02-2014, 04:33 PM
jspridge
jspridge's Avatar
Thanks very much!
Old 07-02-2014, 08:40 PM
Theta
Theta's Avatar
All of the audio system is now posted... phew - that took a while!
Old 07-24-2014, 09:19 PM
millers1
millers1's Avatar
Any info on how hard it is or what's involved in changing the plenum cover?
Old 07-24-2014, 09:44 PM
Theta
Theta's Avatar
It's not hard at all. The thermal pad on top of the intake manifold does require the intake manifold to come out, though (if you don't want to damage it).
I will put up a guide on the manifold removal and perhaps the throttle body since those are becoming more popular.
Keep an eye out for the intake manifold guide, as it will have the prerequisites of plenum removal.
Old 08-15-2014, 05:41 AM
drewauby5
drewauby5's Avatar
how about a DIY for brake caliper removal and reapplication with parts necessary to perform. I am going to have my calipers powdercoated and had done the same on my C6 and there was a great step by step with pictures posted in the C6 section. Thanks in advance, Andrew
Old 08-31-2014, 02:18 AM
Asterism
Asterism's Avatar
Originally Posted by Theta
It's not hard at all. The thermal pad on top of the intake manifold does required the intake manifold to come out, though (if you don't want to damage it).
To Master List of How-To Guides for C7 Corvette Stingray
Old 08-31-2014, 03:06 AM
Theta
Theta's Avatar
Originally Posted by Asterism
I'll make a note to do this tomorrow - been way behind on a lot of things.
Old 09-01-2014, 08:37 AM
drewauby5
drewauby5's Avatar
Default calipers
any help on caliper removal and reinstall instructions??? THanks
Old 09-01-2014, 02:02 PM
Theta
Theta's Avatar
Also working on this now. ETA is around an hour for both of these requests.
Quick Reply: Master List of How-To Guides for C7 Corvette Stingray
