Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- How to Install Headers and Exhaust
Step by step instructions for do-it-yourselfers.
How-To: Remove/Replace Exhaust Manifolds, Cats, X-Pipe / Prep for Header Install
St. Jude Donor '14-'15
The following How-To covers the explanation of how to Remove/Replace the OEM Exhaust Manifolds, Cat Pipes, Intermediate X-Pipe and Prepare for a Mid-Length or LT Header Install and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
The following 2 users liked this post by Theta:
Pizz (04-10-2018),
Yourconfused (05-29-2020)
4th Gear
Replacing stock exhaust with Corsa
I plan on replacing the stock exhaust (cat back) on my 2015 C7Z51 with a Corsa Sport (double helix pipe and back). Anyone know if the swap will trigger warning lights and if an emulator is available to override/turn off the lights?
Lastly, will my rev match function be affected after the Corsa install?
Caig
Caig
Caig
Caig
The Auto Rev Match is unaffected, as it is controlled by the CCM. There's no correlation between the two.
I'm looking to wrap my exhaust pipes. Other than loosening the pipe connectors, disconnecting the hangars, and unbolting the mufflers, looks like there are some actuators I need to unplug way up where the pipes bend up around the rear axles and just in front of the mufflers. Will the pipes slide out or are there any other hidden obstacles?
2016 NPP exhaust
Anyone have PNs for the "one time use" exhaust manifold bolts, studs & fasteners?
!00%DISVET (08-19-2017)
