How-To: Remove/Replace Front Bumper Fascia
St. Jude Donor '14-'15
The following How-To covers the explanation of how to Remove/Replace the Front Bumper Fascia and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
Adding an excellent video provided to us by jagamajajaran:
The following 3 users liked this post by Theta:
The following 2 users liked this post by Theta:
!00%DISVET (03-06-2016),
EvilBoffin (05-13-2016)
Sean,thanks for this posting as a lot of us were looking for this procedure.
I'm sure Jag will much appreciate
Mods please make the new rounds of posts by Sean stickys
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,819 Likes
2015 C7 of the Year Finalist
You do not have to remove the wheel liner to get the front bumper off. 3 fasteners, then reach in and disconnect the side lights and that's all that needs to be done in the fender liner area.
Elmer
Elmer
CF Old Timer
This thread has been extremely useful, also this thread is a must if your car panels are tight like mine were. There are a couple more bolts that required loosening. PLEASE read this is you are having any issues popping off the bumper cover near the headlights.
https://www.corvetteforum.com/forums...e-install.html
After loosening these extra bolts, it was a breeze. Just remember to align and tighten after.
This thread was extremely helpful. I did have trouble with two m7 bolts just under each headlight. You have to remove all fasteners listed, then lift up the from fascia a bit and use a long extension to loosen them to pop the fascia up. Be sure to align the fascia and re-tighten when you re assemble.
Elmer
firesam23 (12-24-2016)
I blew my engine and need to remove the oil tank for cleaning (2017 Z06). I have the GM service manual and have read a lot of post. To get it out you need to remove the front right fender which requires you to remove the front bumper cover/Faicia (sp). There are two screws that appear to be connect the bumper cover to the front right fender. These seem impossible to get at.
I have included a picture to help. Circled in red is the right side side marker electrical connection for reference and circle in yellow are the two screws I am taking about. What am I missing here???
Thanks.
Thanks.
watch the video above and at the 4:10 point you will see what is going on there. you dont remove those screws those screws hold the clip that the notches in the bumper cover fit into. you may have to pull pretty hard to get the cover to come out of that clip but it will pop out.
