Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
- How to Install Shock Absorbers
Step by step instructions for do-it-yourselfers.
How-To: Remove/Replace Front Shock Absorbers
St. Jude Donor '14-'15
The following How-To covers the explanation of how to Remove/Replace the Front Shock Absorbers and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
Theta...Thanks for this! Over the years I've found "Book" instructions often include steps that you can cleverly work around. Knowing also that some are reluctant to undo control arm mounts I tried without. Sure enough..Easy!
1) Car in the air, suspension at full droop
2) Support lower arm with a jack.
3) Remove the lower two shock bolts
4) proceed to the other side and also remove lower bolts
5) Let the jack down and the suspension will sag another 1/2 inch. Just enough to work the shocks out without touching the upper control arm mounts. Takes a little wiggling but easy
Hope this helps a few doing this!
Move lower shock forward and over the lower arm:
Twist and drop out toward the front.
The following 2 users liked this post by Modshack:
emperors61 (07-16-2022),
Jet Vet (12-23-2015)
