The Grond Chronicles : Reincarnation Part 6 [Dialup; Perpetual Wretchedness]
Supporting Tuner
As always, full details of The Grond Chronicles are at http://www.grond.tv
Precis : Shattered Hammer, soon to be Reforged…
Part 1 of The Grond Chronicles : The Reincarnation, dealt with stripping the body panels and removing the entire drivetrain and engine. Details are here
Part 2 documented the complete engine teardown and looked like a scene out of Chernobyl. Details are here
I then auctioned off 2 of my melted pistons to benefit St. Jude Childrens Hospital on the Corvette Forum. That auction raised $2400 for the sick kids - here
Part 3 covered the interior demolition. Details are here
Along the way, I bought this – a JL Audio 18inch subwoofer. And a few amplifiers…
Part 4 documented how to install 4.5inch tubs on a C5 Coupe and a weld-in custom 6 point chrome moly roll cage (cage courtesy of Cajundude). Details are here
At the end of Part 4, I bought a brand new bare LS2 block - here
Part 5 covered the build of the custom fibreglass enclosure for the mega subwoofer, false floor, the beginnings of the amp racks, and targa top storage. Details are here
During Part 5, I became a Supporting Tuner - here
Part 6, that you are reading now, will detail the installation of a ratchet shifter connected to a 4L60E transaxle transmission. This is a C5 first!
Parts 7, 8, 9, etc. I will reveal as time goes on. This project will stretch for several months – at least until March 2007 - so please pull up a chair, open a cold one and get comfy.
So without further ado, here are the pics.
EG
Is there any interest in this as a turnkey mod?
Currently this is a weld-in permanent mod but I am thinking of offering this as still a custom mod - but turnkey and bolt-on - new shifter, housing, custom console and shift boot.
It will look stock when completed and only one x 1 inch hole will need to be drilled in the tunnel - no cutting and no welding!!
Any Interest??? Please post in this thread if you would be interested in this mod for your automatic C5...
Let's start with a B&M Pro Ratchet Shifter
I was told categorically by B&M that this shifter will NOT work in a Generation 5 Corvette. I had the same answer from Jeg's, Summit Racing et al...
So naturally I am going to try and make it work..
Started by fabbing up a bracket or two
And spending a lot of time fine tuning...
But after all that work, I realise too late that the 6 foot cable that ships with the shifter is w-a-y too short...
So ordered a 12 foot cable from Jeg's (cost $60 )
OK. Let’s get to work on the shifter!!
EG
Originally Posted by EnglandGreen
Many folks have asked me to post a new thread every time I post updated pictures. That will not work, and here are the reasons why :
I am trying to keep it to 1 thread per major modification from start to finish. Unfortunately it never quite works out that way and always goes way off topic all the time.
Even so, I don't want to break them up into dozens of tiny threads as it will make it too hard to have continuity with each major mod.
So please set your "View" settings at 100 posts per page. Problem solved
UserCP (User Control Panel) - top menu
http://forums.corvetteforum.com/usercp.php?
Then "Edit Options"
http://forums.corvetteforum.com/prof...do=editoptions
Then "Edit Options"
Supporting Tuner
Let's begin with the stock automatic shifter.
I hate this shifter!!! Forget shifting fast up or down - I have missed so many shifts... Grrrrr....
Now this is what the doctor ordered But its too high...
That's better..
And it will look stock...
Garage Queens - Avert your eyes!!!!!!
Don't try this at home...
That's better...
This just may work... if I can clear the torque tube...
Not a lot of depth to play with - only 2 inches....
Pause for a quick modification of the console (read: cut it up )
Real men can't drive stock...
I love my Dremel
That's better..
That's better...
I love my Dremel
Supporting Tuner
OK. Back to the shifter. Where was I?
Oh yes, made a template and offered it up
If I can get it at this height, this will look way cool
Transfer the template to steel...
Drill the mounting holes...
And cut it out
Smooth the edges...
And try it on for size...
Good fit... still concerned about torque tube clearance though...
And cut it out
Smooth the edges...
Supporting Tuner
The moment of truth (tunnel viewed from below)
Remember, this is a permanent mod!!
First tacks
This is the biggest downside to working alone. I end up having to jury-rig all sorts of Heath Robinson (Rube Goldberg to my American friends) contraptions just to do simple tasks.
Made this stand to hold the shifter base while I tacked it in place - or course, it caught on fire...
Now for the side support
Tacked in place
OK. Ran some beads on this bad boy
And on the top. It isn't going anywhere!
First tacks
Tacked in place
Supporting Tuner
I ended up having to mount it higher than I would have liked
But the torque tube clearance was just too tight
It is extremely solid!!!!
Relieved the console for clearance
I was going to make a custom console anyway, so this does change not represent any more work
Let's see how it looks populated...
Sweet!! It clears the AVIC N2 by a mile!
I am very pleased with how this mod has turned out
And the feel of the shifter... Rapture!!!!
Sand, clean and Black rattle-can
Just the rubber weatherproofing to mount. It looks stock!
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Placeholder 1
Placeholder 2
Placeholder 3
Placeholder 4
Stephen, there's dust on your drivetrain...perhaps it's time to use that stuff, afterall, Rodney built it for your car, not your garage
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I find it easier to load up each reply complete in a seperate tab and then click, click, click, submit each reply in succession...none of this placeholder crap while we all
Never had anyone sneak a reply in between.
Location: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Placeholder 2
Placeholder 3
Placeholder 4
Talk aboot getting your post count up
Life Time NCM #2196
Originally Posted by Stangkiller
I'm a sneaky bastard though...i got that last post in just incase there was to be a place holder 5
Scientific Negotiator
Received 1,836 Likes
St. Jude Donor '07-'08-'10, '14
That's lame! Post pictures!
CRAP!!! I just made page one of an E.G. post...
(feel like I accomplished something)...
Oh, and even better:
Stephen, the Shifter's looking great! As i've said before, i can't wait to drive it!
I hope that metal i picked up is working out well.
Be prepared...he's going to advise you to run 100 posts per page
Can't wait to see this thing done Stephen... DANG!
This is the biggest downside to working alone. I end up having to jury-rig all sorts of Rube Goldberg contraptions just to do simple tasks.
EG
Once you get a lift some of the things will become easier when working alone
Supporting Tuner
All pics are now posted with commentary anyway
Supporting Tuner
Stephen, can't the "arms" those ends of the shifter be cut off for a better fitment?
This thread is worthless without pictures of the fire.
Stephen looking for the extinguisher.> WooWooWoo!
