[Z06] Tire pressure sensor wheel specs
Former Vendor
So my saga to find wheels here in the UK continues. I have now measured all the relevant data to get a wheel that will fit, but what is the spec for the wheel rim in order to get the TPM sensors to fit?
Is there a specific hole size for the valve stem?
Are there shape/clearance issues for the sensor, i.e. only certain rim thicknesses and angles?
Failing the above, is there anyway to disable the TPM system so that all TC/AH modes can still be accessed without warnings?
I know I can order a set of wheels from the many fine vendors here on the forum but the cost of shipping plus the ridiculous UK import taxes make that prohibitively expensive.
I'm just looking to put a set of 18" wheels on so I can get some decent rubber on!
Butt.....there's no way to disable the TPMS. Unless you're going for a full-on race car, in which case you can remove the Body Control Module and Remote Control Door Lock Receiver Module computers.
If you have real problems with mounting the sensors in the valve stem holes, some owners have "banded" them inside the wheels with long nylon straps or metal hose-clamps. There also is apparently a bracket that allows you to mount the sensors inside the wheel. See the threads below (in the second one, scroll down to post#14 to see info on how dark_phantom mounted his with brackets):
http://forums.corvetteforum.com/show....php?t=1412003
http://forums.corvetteforum.com/show....php?t=1617584
Bob
Here's a link to another thread that, in post# 3, are some pictures of a sensor and how they mount in a stock wheel.
http://forums.corvetteforum.com/show....php?t=1642186
Bob
Bob
Former Vendor
Cheers Bob!
I think those pics are all I need.
Does anyone know what CCW and Forgeline do about the sensors? Do they mount normally or do they need to be epoxied in?
David,
I banded mine in with no epoxy. Instead I used wire ties. This way you can remove them easily. They make no noise whatsoever. I ran them all last year at the track with no issues.
Mike
Mike
I've been over there and John has an absolutely top-notch operation. Those are incredibly strong wheels - good looking and priced right, too! They have among the highest reputation for great customer service, as well.
I know most all their wheels are built to accept the sensors in stock location.
http://www.ccwheel.com/files/home.php
Bob
Melissa
CCW
I can't answer for CCW or Forgeline, but most of the HREs are directly compatible with the factory TPMS mount.
Mike
This is how the C4's were done. Although there were some issues, overall it was a success.
Clay and Martin, This isn't entirely true. There is a Forum member here who had a real problem with his HREs. BUT, He did run a 20" wheel with a low profile tire. The TPSM dug a hole on the inside of the tires and trashed it. Yes, it was installed properly by an authorized HRE dealer, I saw it in person. If you'd like further details, PM me and I'll let you know who to contact. He's still trying to resolve it amicably.
Mike
Mike
Former Vendor
Thanks for all your help guys!
The metal bands that Mike uses look similar to the ZR1's.
My friend was driving his 1990 ZR1 alongside me in my L98 and we both had the shock of watching the tread of his rear tyre come rolling past us!
It appeared that the metal band holding the TPM sensor had broken and flailed around inside the tyre, eventually causing the tread to separate from the sidewalls.
Amazingly he could just drift to the side of the road and stop, but if he had been cornering hard at the time, it would have been a whole can of interesting...
Can Forgeline's rims come with any other finish other than polished? I'm not sure polished bare ali works too well in the UK climate!
I know CCW make painted/anodized one piece wheels, but I prefer the look of the 3 piece ones like the Forgelines.
