HELP!!! , reset navigation.
Hi,
How I can reset your navigation? I can not set the clock I can not act the clock, is blocked the clock, the clock is blank Thanks |
It sounds like your trying to set the clock. Hold you finger down on the screen over the time until the window for resetting shows up.
Originally Posted by EVRose
(Post 1579227664)
If you just push and release the time display on the nav screen, it will tell the current day and date. If you push and hold the time display for about 5 seconds, it will bring up the page to reset the clock. You need to do this for driver (fob) #1, and then switch to driver (fob) #2 and do it again. Good luck to you! |
thank you very much.
.. pulse display, and not indicate the date. .. my Navegation is American, no position in Spain. .. that is the problem ??? |
Sorry, I don't know.
Originally Posted by Gearhead Jim
(Post 1579236379)
nobody knows I can do??
Thanks |
If you can access the clock information as described above, there's a GPS time button you can turn off therefore manually setting the clock. I don't know if there's a NAV disc or other way of setting up the NAV for Spain. I know GM exports cars over there so there must be a way of doing this. You might contact GM Customer Service directly for this and see if they can help you.
Originally Posted by dgrant3830
(Post 1579257161)
Been there, seen it...:thumbs: Fred |
There is a way of deleting the "Home" address of the previous owner and its in the menus there somewhere. There's a link to the NAV functions here in the forum and I'll see if I can find it. Here is the instructions...BTW, simple search found it in here "Using the C6 Nav"
Stored Locations Once a destination has been stored, the address information can then be edited and deleted. See Stored Locations on page 40 for more information on other features that can be stored, edited, and deleted. To delete the stored home destination, do the following: 1. Press the power/volume knob to turn the system on. 2. Insert the DVD map disc. See “Installing the Map DVD” under Maps on page 67 for more information. 3. A notice may appear. Touch the Agree screen button to proceed. If the radio is already on with a map disc inserted, press the NAV hard key. 4. Press the MENU screen button. 5. Press the N Stored Locations screen button. 6. Press the L Home screen button. 7. Press the Delete screen button. 8. A confirmation pop-up screen will appear: select Yes to delete; select No to cancel the operation. To delete a waypoint or a stored preset destination, do the following: 1. Press the power/volume knob to turn the system on. 2. Insert the DVD map disc. See “Installing the Map DVD” under Maps on page 67 for more information. 3. A notice may appear. Touch the Agree screen button to proceed. If the radio is already on with a map disc inserted, press the NAV hard key. 4. Press the MENU screen button. 5. Press the N Stored Locations screen button. 6. Press the$Dest. & Way Pt. or the & Previous Dest. screen button. 7. Press the Delete screen button, then select the way point or the numbered preset button to delete. 8. A confirmation pop-up screen will appear: select Yes to delete; select No to cancel the operation. http://forums.corvetteforum.com/c6-c...rough-5-a.html |
Thakns.
Dgrant3830, this is to set the time ?? |
