Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-15-2011, 06:03 PM   #1
itorfeo
Junior Member
itorfeo's Avatar
Default HELP!!! , reset navigation.
Hi,
How I can reset your navigation?
I can not set the clock
I can not act the clock, is blocked the clock,
the clock is blank
itorfeo is offline   Reply With Quote
Old 11-15-2011, 07:10 PM   #2
EVRose
CF Senior Member
EVRose's Avatar
It sounds like your trying to set the clock. Hold you finger down on the screen over the time until the window for resetting shows up.
EVRose is online now   Reply With Quote
Old 11-15-2011, 09:04 PM   #3
Gearhead Jim
CF Senior Member
St. Jude Donor '13
Support Corvetteforum!
Quote:
If you just push and release the time display on the nav screen, it will tell the current day and date.
If you push and hold the time display for about 5 seconds, it will bring up the page to reset the clock.
You need to do this for driver (fob) #1, and then switch to driver (fob) #2 and do it again.
Good luck to you!
Gearhead Jim is offline   Reply With Quote
Old 11-16-2011, 06:25 PM   #4
itorfeo
Junior Member
itorfeo's Avatar
thank you very much.
.. pulse display, and not indicate the date.
.. my Navegation is American, no position in Spain.
.. that is the problem ???
Old 11-16-2011, 06:57 PM   #5
Gearhead Jim
CF Senior Member
St. Jude Donor '13
Sorry, I don't know.
Old 11-16-2011, 07:14 PM   #6
itorfeo
Junior Member
itorfeo's Avatar
Quote:
Old 11-17-2011, 06:04 PM   #7
itorfeo
Junior Member
itorfeo's Avatar
nobody knows I can do??
Old 11-19-2011, 08:37 AM   #8
dgrant3830
Wounded Warrior Escort '11
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
If you can access the clock information as described above, there's a GPS time button you can turn off therefore manually setting the clock. I don't know if there's a NAV disc or other way of setting up the NAV for Spain. I know GM exports cars over there so there must be a way of doing this. You might contact GM Customer Service directly for this and see if they can help you.
dgrant3830 is offline   Reply With Quote
Old 11-19-2011, 06:30 PM   #9
fred_S
CF Senior Member
fred_S's Avatar
Quote:
If you insert the Western Europe DVD the nav system will work perfectly. If you import a car from the US to Europe and it still has the home address of the US owner there will be an error saying "no map data for this location". Which is normal because the Europe DVD doesn't cover the US.
Been there, seen it...
Fred
fred_S is online now   Reply With Quote
Old 11-20-2011, 07:41 AM   #10
dgrant3830
dgrant3830's Avatar
There is a way of deleting the "Home" address of the previous owner and its in the menus there somewhere. There's a link to the NAV functions here in the forum and I'll see if I can find it. Here is the instructions...BTW, simple search found it in here "Using the C6 Nav"
Stored Locations
Once a destination has been stored, the address
information can then be edited and deleted.
See Stored Locations on page 40 for more
information on other features that can be stored,
edited, and deleted.
To delete the stored home destination, do the
following:
1. Press the power/volume **** to turn the
system on.
2. Insert the DVD map disc. See “Installing the
Map DVD” under Maps on page 67 for more
information.
3. A notice may appear. Touch the Agree screen
button to proceed.
If the radio is already on with a map disc
inserted, press the NAV hard key.
4. Press the MENU screen button.
5. Press the N Stored Locations screen button.
6. Press the L Home screen button.
7. Press the Delete screen button.
8. A confirmation pop-up screen will
appear: select Yes to delete; select
No to cancel the operation.
To delete a waypoint or a stored preset
destination, do the following:
system on.
information.
button to proceed.
6. Press the$Dest. & Way Pt. or the &
Previous Dest. screen button.
7. Press the Delete screen button, then select
the way point or the numbered preset button
to delete.
http://forums.corvetteforum.com/c6-c...rough-5-a.html
Old 11-20-2011, 08:08 AM   #11
itorfeo
Junior Member
itorfeo's Avatar
Thakns.
Dgrant3830, this is to set the time ??
Reload this Page HELP!!! , reset navigation.
Tags
2006, c6, corvette, forum, home, nav, navigation, reset, system, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
