Wheel spacers - Base C6
Not wanting to spend the money on new wheels / tires, thought about pushing the wheels out somwhat with wheel spacers. Anyone done this? Pictures? Have the '09 "gumbys" on the car and think with them pushed out somewhat would look a bit nicer than tucked back.
What size would I need to go with? I see Southern Car Parts have them. Any other thoughts / suggestions?
Thanks.......
Thanks.......
I needed wheel spacers on my C6 for bigger brakes on custom rims but removed them cause with the wheels sticking out a bit the tires kicked up anything on the road on to the side body panels.
Paulgta (11-18-2017)
I have actually read a few threads where forum members have used small spacers to push the wheels out slightly. (maybe 1/4 to 3/8).
Some have done it to clear Z06 brakes (with the gumbys) on a narrow body.
You would have to go with longer studs to do that though.
Cool, I wish you had a pic. Are these adapters the type that have studs located between the 5 holes? If so do you know what thicknesses are available in this type of spacer? I had a set that were 11/16" thick that I used on a C4 but I don't know a source now. They were perfect for the 88-up C4. The downside is adding unsprung weight from the extra studs and nuts.
they are adapters not spacers, anything thinner than 1 inch isn't safe. Not much holding the bolts.
Here's a couple recent threads that may help with your decision.
http://forums.corvetteforum.com/c6-c...er-offset.html
http://forums.corvetteforum.com/c6-c...questions.html
Corvette Enthusiast
I'm running 8mm Spacers all around with ET lugs, no issues, and you can't even tell they are pushed out.
This was done so I can buy Z06 brakes. With 8 mm you will clear the caliper with Gumbys.
I'm running 1/4" spacers in front and 3/8" spacer in the rear. My C6 is lowered as well and the fit is perfect for me.
No rubbing or other issues.
I went ahead and installed the 1/2" ARP studs for peace of mind.
1/4" spacers all around here. On a 2 /2" drop. No rubbing even at 150mph plus. I used the E lugs. There extended to grab more threads. I get like 9 turns on my lug nuts. The first pic is after I installed 1/4" spacers, the last 2 were 1/8" spacers.
http://ls1tech.com/forums/attachment...ttes-photo.jpg
http://ls1tech.com/forums/attachment...es-photo-1.jpg
http://ls1tech.com/forums/attachment...es-photo-2.jpg
Hey. I saw you out of the corner of my eye. My wife and I were checking out your car when it was in front of the bank machine. I need your center console. Lol nice car man.
