Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-21-2008, 06:28 AM   #1
SunsetOrangeCreations
Premium Supporting Vendor
SunsetOrangeCreations's Avatar
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out my website @ www.sunsetorangecreations.com
Default Add Bi-mode exhaust to ANY C6 with the Exhaust Commander All-in-1 NPP retrofit kit
ADD NPP bi-mode exhaust to ANY C6!
Exhaust Commander All-in-1 bi-mode exhaust vacuum retrofit kit
has the exclusive feature of Zero Battery Drain remembers last setting mode!
Its another Sunset Orange Creations innovation! Whatever setting you shut the car off in, is the way it starts up.
Exhaust Commander All-in-1 NPP retrofit kit also has the exclusive feature of being able to be installed in the car WITHOUT having to drill ANY holes in your car! Why Drill into your car when you dont need to?
Now Available with the Exhaust Commander D.A.S.H. controller which allows you to control you bi-mode exhaust from your dash D.I.C. reset button. Click Here to Read All about it! Its also available with Lear Car2U universal visor control as an option!
Get the best system available and have one that remembers!
Order Here:
This is a new option available on the All-in-1 bi-mode exhaust retrofit kit that I have been selling for the last year. Works on all C6's 2005-2010.
Its always been 100% Zero Battery drain since its inception, now with this exclusive Sunset Orange Creations new feature its even better!
Here is a post outlining how one of my engine vacuum systems installed and used by Flareside and BaddBilt1 back in May 2007.
http://forums.corvetteforum.com/c6-t...om-engine.html
With this bi-mode vacuum retrofit solution you get everything you need to control your retrofitted
bi-mode exhaust and get the option to now have a ZERO BATTERY DRAIN remembers last
setting mode
. Whatever position your butterflies are in when you turn the car off, is the
position they return to when you start the car again.
This system is 100% Zero Battery drain!
Using a special non-volatile memory, I have created a system that is powered off when the car is off
so that there is no battery drain at all, yet it retains its memory so it comes back to life exactly as it
was shut down. Shut down the car in quiet mode? It will start in quiet mode. Shut it down in loud mode,
and it will start up in loud mode. Its a revolutionary new feature available right now with the
Exhaust Commander All-in-1 bi-mode exhaust retrofit kit.
The Exhaust Commander No Splice rpm opening option I developed is also available available with this kit!
This NPP vacuum retrofit kit includes the wireless controller with one button keyfob remotes,
spare keyfob remote batteries, and all
of the necessary vacuum lines, vacuum solenoid and wiring to complete the control system installation.
It will give you full open / full closed modes and gives you the ability to switch between the modes
instantly using the supplied One button wireless remotes.
Typical install time is around 1 or 2 hours.
NO holes need to be drilled in your car, and everything could be removed without a trace if you wanted to.
These systems are assembled and tested by Me personally, right here in the USA!
Quick install summary:
1: The engine vacuum tap used is the correct GM bi-mode vacuum port on the back of the
intake manifold, just like the 2008-2009 NPP C6, Z06 and ZR1's use. Not the brake booster or other critical
engine sensor systems. Do it right just like the GM factory does it. The GM engineers that designed the bi-mode exhaust system know the most reliable way to tap vacuum for the system is at the rear intake vacuum port.
The vacuum line is run above the tunnel plate from the engine to the
vacuum solenoid unit and then you hook up the vacuum lines to the butterfly valves on the mufflers.
2: You have the option to mount the vacuum solenoid box inside the car completely out
of the elements OR outside the cabin depending on your install preference. If you choose to mount it outside the car, NO HOLES need to be drilled to install the system. You choose!
3: The wireless controller is located in the passenger fuse panel area just like all my innovative Exhaust Commander controllers allowing controller upgrades when they become available! The power cable is run
easily from the passenger footwell area to the rear of the car by tucking it underneath the trim panels.
4: Once everything is hooked up, Start the car and enjoy your fully operational bi-mode
exhaust system!
This is a great vacuum retrofit system for those who want to retrofit bi-mode exhaust to their C6
that didnt come with it. All you need is the All-in-1 kit and the bi-mode mufflers and you have a
functioning bi-mode exhaust.
Simple to install, and available with features that Corvette enthusiasts demand!
This kit allows you to start in either open or closed modes with a remembers last setting mode.
Always 100% Zero Battery Drain . Only $179.95 plus shipping!
Also available, Exhaust Commander D.A.S.H. dash D.I.C. reset button control
so you can control your exhaust right from your dash D.I.C. reset button!
My revolutionary RPM opening option is also available so you can have a fully functioning system with user selectable rpm opening if you want it.
I believe this is the best Bi-mode retrofit system I have ever created!
Sunset Orange Creations will continue to develop new and improved, exciting products
for the Corvette enthusiast.
I am looking forward to helping you in the future with any of your bi-mode exhaust needs.
Feel free to contact me anytime with questions or custom system requirements.
Ben
SunsetOrangeCreations is offline   Reply With Quote
Old 11-25-2008, 02:11 AM   #2
Add bi-mode exhaust to YOUR C6!
The Exhaust Commander All-in-1 NPP retrofit kit has many options to choose from. Wireless keyfob remotes, Dash DIC control of the butterflies, Zero Battery Drain remembers last setting mode, User selectable rpm opening mode.
Each system is custom built to your specifications!
Do your want the highest quality most technologically advanced bi-mode retrofit system?
Choose Exhaust Commander!
Old 11-28-2008, 05:39 AM   #3
Thanks to all who have ordered an Exhaust Commander All-in-1 bi mode exhaust vacuum retrofit kit.
Judging by the demand it looks like the new Zero Drain remembers last setting mode option is a HIT!
Ben
Old 11-28-2008, 12:10 PM   #4
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.128
This is a great kit guys. Bens products are hands down the best on the market and the customer service can't be beat.
RICH
RichieRichZ06 is online now   Reply With Quote
Old 11-30-2008, 05:56 AM   #5
Quote:
RICH
Thanks Rich!
Hope to see you out at some of the local events now that my car is done.
Ben
Old 12-03-2008, 07:52 PM   #6
danl72
CF Senior Member
danl72's Avatar
Send a message via Yahoo to danl72
Very cool.
danl72 is offline   Reply With Quote
Old 12-06-2008, 06:15 AM   #7
How to get the vacuum cap off the back of a LS2 or LS3 manifold.
I have installed over 20 of my NPP retrofit systems personally and have popped that damn cap off so many times I have it down pat and can do it in 5 minutes or less now.
Here is the secret.: Use a small x-acto knife to score / cut through the the place where the cap twists off at. There is a little groove where you can place the blade and then score / cut the cap off. If you can get a decent score on the line or even cut through it about 1/3 to 1/2 way it will twist right off with little or no effort at all.
Hope that helps and enjoy you bi-mode exhaust!
Ben
Old 01-06-2009, 04:49 AM   #8
Here is a video of JB's LS3 gaining 8 HP and 8 tq using the Exhaust Commander all-in-1 NPP retrofit kit and Z06 3 inch mufflers.
JB's LS3 gaining 8 HP and 8 Tq using an Exhaust Commander all-in-1 NPP retrofit kit
Way to go JB, that thing is a monster!
Ben
Old 01-09-2009, 06:12 PM   #9
Norm66
CF Senior Member
St. Jude Donor '08-'09-'10
Norm66's Avatar
RICH
Norm66 is offline   Reply With Quote
Old 01-17-2009, 06:28 AM   #10
Thanks to all who have ordered!
I am looking forward to hearing how you like your new controller.
Ben
Old 01-20-2009, 10:22 AM   #11
jmt1669
CF Senior Member
St. Jude Donor '11
jmt1669's Avatar
Can you tell me how many keyfob remotes come with your kit.
jmt1669 is offline   Reply With Quote
Old 01-21-2009, 02:13 AM   #12
Quote:
As many as you need, there is a drop down menu that lets you pick 1, 2 or 3 remotes.
Ben
Old 01-23-2009, 10:09 AM   #13
jmt1669
CF Senior Member
St. Jude Donor '11
jmt1669's Avatar
Quote:
Ben
Just placed my order! The factory vacuum mounting location was my deciding factor.
Old 01-25-2009, 07:13 AM   #14
Looking forward to hearing how you like your bi-mode exhaust!
Ben
Old 02-13-2009, 04:05 PM   #15
jmt1669
CF Senior Member
St. Jude Donor '11
jmt1669's Avatar
PM sent
Old 06-15-2009, 01:33 PM   #16
T's C6
CF Senior Member
T's C6's Avatar
Ben
I installed the kit this weekend and all went well but that damn cap, it is the biggest pain in the A**. There is no room for a regular hand to get in there to remove it. We spent 2 hours messing with the cap. Your instructions need to have or give a better instruction on this instead of just saying to just twist it off. it is very miss leading!
Besides the cap issue (instructions) it is a great product.
T's C6 is offline   Reply With Quote
Old 06-15-2009, 02:17 PM   #17
nwc6
CF Senior Member
The cap is a PIA..I used an exacto knife duct taped to a nut driver to saw it off.
nwc6 is offline   Reply With Quote
Old 06-15-2009, 06:27 PM   #18
Yes the vacuum cap is a PITA, no bs about that. Instructions now say try and twist and then cut if needed.
I have been able to twist some off, and some others I had to cut off, it all depends on the car.
I am glad you got it, and you should know that you have used the CORRECT GM vacuum tap area for bi-mode exhaust.
Here are a couple of pix of the offending vacuum cap:
Glad you have your bi-mode exhaust up and running.
Ben
Old 07-17-2009, 10:08 PM   #19
j_digi454
CF Senior Member
Support Corvetteforum!
j_digi454's Avatar
Get one Now! Add NPP to YOUR car!
This unit has the Zero Battery Drain remembers last setting mode built in! It will remember its last setting AND is Zero Battery drain!
Spare keyfob remote batteries included.
Also, Dash DIC reset button control and user selectable RPM opening are available as options!
Ben
Ben, my DASH unit is up and running as well, I (my son) had to virtually cut thought 3/4 the way to get the vacuum cap to break off. It took someone like my Son with longer thinner arms and hand to get in there to cut it off.
It is working as designed.
j_digi454 is offline   Reply With Quote
Old 07-17-2009, 10:10 PM   #20
Thats great news!
Glad you are enjoying being able to open and close your retrofitted bi-mode exhaust right from the dash DIC! No remotes needed.
Have fun and make some noise out there.
Ben
Reload this Page Add Bi-mode exhaust to ANY C6 with the Exhaust Commander All-in-1 NPP retrofit kit
Tags
2005, 2007, adding, bi, c6, controller, corvette, exhaust, mode, npp, reset, retorfit, swith, upgrade, visor
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
