Convertible lid strut replacements
1 Post
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '07-'09
I am going to replace the struts on my convertible lid when I get home. Any suggestions on the easiest way or shot cuts?
Here ya go:
Document ID# 656600
2002 Chevrolet Corvette
________________________________________
Folding Top Stowage Compartment Lid Struts Replace
Removal Procedure
1. Open the folding top stowage compartment.
2. Remove the forward end of the strut from the hinge ball stud.
3. Close the folding top stowage compartment lid.
4. Open the rear stowage compartment lid.
5. Remove the strut from the rear ball stud.
Installation Procedure
1. Open the rear stowage compartment lid.
2. Position the rod end of the strut through the access hole between the quarter panel and the support.
3. Install the strut to the rear ball stud.
4. Close the rear stowage compartment.
5. Open the folding top stowage compartment.
6. Install the rod end of the strut to the front of the hinge.
7. Close the folding top stowage compartment.
Document ID# 656600
Removal Procedure
1 Post
Cruise-In V Veteran
Do they just pry off or is there a pin or bracket that needs to be removed?
Search is your friend:
http://forums.corvetteforum.com/c5-g...tallation.html
I recently replaced mine using the method described in the link.
Got the new ones on ebay for $28 including shipping.
When I got on the "fleabay" site I got confused but as soon as I saw the "click on Chevrolet" and then put in Corvette in the "search" bar; all was clear. My bad. Thanks for the help, ordered and on the way. Hope the installation is as easy as the ordering!
