Old 03-11-2015, 01:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
Convertible top hatch strut installation.
Old 09-14-2011, 03:54 PM
Ultimate ride
Ultimate ride's Avatar
Default Convertible top hatch strut installation.
My vert top hatch struts needed replaced as the hatch would no longer stay up by itself. I did a search on changing them, but wasn't satisfied with the results I got. So, here is how I changed them.
1. Open the trunk. Look under the sides and you will see the struts.
2. Pry off both the spring clips with a screwdriver or scratch awl.
3. Close the trunk.
4. Open the top hatch and prop it up in the fully raised position. The strut is now in the fully extended position and not under pressure.
5. Reach down and pull the strut off the ball joints.
6. Close the top hatch.
7. Open the trunk and snap the new strut on the aftermost ball joint, making sure that the rod end is positioned toward the front of the car.
8. Close the trunk.
9. Open the top hatch and snap the rod end on the forward ball joint.
The hatch will now stand up by itself.
10. Repeat for the other side.
Once I figured this method out, it took less than 5 minutes to complete the job. I didn't take any pictures, but when you look under the sides of the trunk, it is all pretty obvious.
The following 6 users liked this post by Ultimate ride:
Alley Oop (08-11-2018), buckeye1872 (11-30-2015), C5 4me (10-17-2018), gowenfast (10-18-2018), TooMch (04-30-2016), WetMountainMan (09-07-2018) and 1 others liked this post. (Show less...)
Old 09-14-2011, 04:17 PM
Vettmann17
Vettmann17's Avatar
3. Close the trunk.
8. Close the trunk.
Thanks for the writeup, hopefully mine will last the life of the car but if they go it's good to know it's not a hard job.
Old 09-14-2011, 04:19 PM
Kevin Kuse
Kevin Kuse's Avatar
That is what worked for me. Doing it like that you don't have to compress the struts, Quick & Easy !
Old 09-14-2011, 07:43 PM
tsbbzm
tsbbzm's Avatar
I need to do this, where did you get the struts and about what did they cost?
Old 09-14-2011, 10:46 PM
Kevin Kuse
Kevin Kuse's Avatar
part number 10275941.
Chevy Dealer approx $20ea.
Old 09-14-2011, 11:28 PM
Ultimate ride
GM Parts House. About $20 ea.
Old 09-15-2011, 09:51 PM
CPhelps
CPhelps's Avatar
Seeing this thread the other day reminded me I need to change mine, thanks for the write up Ultimate, and thanks for the part number, Kevin! Just bought them from Gene at GM Parts House, $23.18 each.
Old 09-19-2011, 08:54 AM
tsbbzm
tsbbzm's Avatar
Thax!
Old 09-19-2011, 09:27 AM
fendermender
fendermender's Avatar
I need these also. Yesterday I decide to have a look see since I have an extra set off a Grand Prix trunk lid. I ended up crawling into the trunk with my legs hanging out. For a while I tought I was stuck in there. BTW, the GP ones are too long.
Thanks for listing the procedure.
Old 04-23-2012, 10:37 PM
hzz
hzz's Avatar
I am getting ready to do this job on my 2003
One question....on the sides of the trunk there are black plastic covers that cover the struts...do they just pull straight off or is there any trick to removing them?
Just want to be sure before I break anything.
Old 04-25-2012, 03:07 PM
hzz
hzz's Avatar
Anybody?
Old 04-25-2012, 03:16 PM
Kevin Kuse
Kevin Kuse's Avatar
On my 98 I did as described below and there were no covers in the way!
3. Close the trunk.
8. Close the trunk.
David Hayden (06-19-2020)
Old 04-25-2012, 06:20 PM
Oldvetter
Oldvetter's Avatar
I just replaced the struts on my 1998 hood. The hood wouldn't stay open this winter, when it was cold.
Old 04-25-2012, 07:18 PM
Ron222
Ron222's Avatar
Did mine a few months back on my '04 vert, used the same procedure as outlilned above and didn't have a problem. Ordered the struts from this link ( http://stores.ebay.com/Lift-Supports...id=p4340.l2563 ). I ordered the ones manufactured by STABILUS (when you remove yours you'll notice STABILUS is the manufacturer that supplied them to GM (at least on my '04, their name is right on the strut) the only difference between the two is that the stabilus has a black cylinder and black plunger, same as OEM, the Strong Arm ones have a black cylinder and a chrome plunger. I received my order in a few days...no problems at all....and the best part is they have a
Lifetime Warranty and I got 2 for $25.00.
They fit perfectly. Hope this helps
Old 04-25-2012, 08:41 PM
WildWolf
WildWolf's Avatar
Just ordered a set. This forum shows me how to spend money like nothing I have ever seen
Old 04-25-2012, 09:00 PM
hzz
hzz's Avatar
Just ordered a set
Old 04-25-2012, 09:25 PM
Ron222
Ron222's Avatar
Just ordered a set
Glad I could help
To Convertible top hatch strut installation.
Old 04-26-2012, 09:35 AM
fendermender
Ordered a set this morning.
Old 05-17-2012, 03:41 PM
azer666
azer666's Avatar
Great post! Ordered and waiting to install.
Old 05-20-2012, 09:04 AM
Praetorian27
Praetorian27's Avatar
Anyone take pics during their install?
Quick Reply: Convertible top hatch strut installation.
