Rear Wheel Bearing Research CONTINUTED
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Rear Wheel Bearing Research CONTINUED
Heres the pics of the RWB dissassembled
P/N found is from the inner race package ET-CRI-0846...NTN...JAPAN
Heres a shot with the outboard bearing group removed.
You can see the other bearing assembly still in place
________________________________________ ________________________________________
Link to GP
Link to GP
I have to give them credit, the rollers are longer than I thought they would be.
I can't tell from the pictures -- are the outer races butted directly against each other?
What is the price of them with a group purchase?
Tom Piper
Tom Piper
That explains why the press I was using couldn't budge it. Time to find a bigger hammer!
NSKF Catalog
Naaa. Not YOU!!
To be determined. I ran a pick past where the parting line should be with no discernable split. The outer race or cups appear to be one piece.
Stay tuned
Stay tuned
I'll take four for now but if the discount is substantial I'll take 6.
EDIT: 2 pairs.
EDIT: 2 pairs.
I'm coming in late to this and I've never looked at the inside of a wheel bearing (though I've had to replace a couple). What's unusual about this setup that is getting everyone so excited? Any estimates what the price might be?
Thanks.
[RICHR]
Thanks.
[RICHR]
http://forums.corvetteforum.com/show....php?t=1827042
then you held a secret that everyone was looking for
Regardless if it is a single race or two races butted directly together, after seeing that drawing, they certainly did the best with the space they had to work with and the tapered rollers should be an improvement.
The unfortunate thing, when comparing the C4 wheel bearing to my C2 wheel bearing is the spacing between the inner and outer bearings.
The C4 bearing assembly is simply much narrower which leaves no room to space the bearings apart -- and I don't know a way to solve that.
In the C2 and C3, the inner and outer bearings, in the bearing housing, are spaced about two inches apart -- for a wide stance.
Between the two bearings is a spacer and shims, the shims can be used to adjust the bearing play.
So, if the bearing develops play, it can be taken apart, greased, and readjusted.
Tom Piper
Tom Piper
