Rear Wheel Bearing research
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
After reading a post that referenced a RWB with taper bearings, I ran a quick search to find some further info. Although the taper bearing question has yet to be answered, heres some ID's for RWB that are sold by the same vendor yet priced suspiciously lower than other vendors.
270157684926 $139.99 Wheel Bearings Direct, *******, MI
270135759727 $69.99 Wheel Bearings Direct, *******, MI
Heres one sold by Tracy Chevrolet, Roseville, MI
270151603254 $119.00
Me thinks these are all the same. Buyers beware?
________________________________________ ___________
Package arrived via UPS from *******, MI looking somewhat pounded.
Upon opening the assembly had shifted in the packaging.
The foam packaging was destroyed. However the assembly appeared undamaged.
Nice overall finish. Looks like I'd expect it should look.
Part Number WB1 513020HD AK842/227/07 (CNC'D, NOT etched)
Hub Side
Shaft Side
If someone will post a pic of a standard bearing showing the shaft side I'd appreciate it.
Next step is to tear it down......
Hub Side
Shaft Side
I bought a full set of wheel bearings off Ebay a few years ago. One of the front ones was junk after 700 miles and one of the back ones was done after 3000 miles. I ended up putting one of my old fronts back on. The guy I bought the rear from warrantied it, but I had the same problem with play after about 5000 miles.
Heres the latest correspondence with the seller:
My Question
His answer
My Question
I'm curious about the taper bearing design that your claiming in this item. To date the only known Corvette RWB assemblies are of dual row ball design. Can you provide any pics or drawings of this item? Also noticed ebay item number 270135759727 for $69.99. Is this the same bearing, or the ball design?
Thanks in advance for your answer. Steve
I will check and see if we have any drawings, I don't think we do. The reason we came out with the taper design is because nobody else had done it. To date it has been a huge success. Item 270135759727 is the stock dual row bearing assembly. As far as pictures I can take some if needed but they both look the same on the outside the bearings are hidden inside. The taper bearing and race are made by timkin. Thanks Ryan
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Timken does make rollers, and not ball bearings, so it could be legitimate.
I'm surprised they speak so highly of them yet can't seem to substantiate it. Or maybe not so suprised.
If 6 people give me 20 bucks, I'll buy one and seperate it on my hydraulic press.
I went to Wheel Bearings Direct's web site and I don't see those part numbers or prices. Also, I didn't notice where either Corvette rear wheel bearing was represented as a tapered bearing. I'll bet the "tapered" bearing is a mistake. Years ago, I took a Corvette rear wheel bearing/hub assembly apart and with calipers and a spec book in hand, I was unable to find a set of tapered bearings that would fit the factory castings regardless of the amount of machining. There just wasn't anything close. I'll be watching to see what develops.
RACE ON!!!
RACE ON!!!
At this point I have no reason to doubt his claim. I've inquired as to how the bearing can be lubed or if the preload can be set. Probably hear back later.
bearing
I e-mailed them through e-bay. My first question was: Is the bearing sevicable? He answered: I dont know what you mean by servicable. Then I returned with; Can it be disassembled and repacked?
He said no. I have had the original rears apart on mine, cleaned and regreased. I would think if the assembly had tapered bearings it could be disassembled for replace or repack. I think whoever replied to me knows little about the assembly.
I think I am the one that first posted this about a week ago.I also posted the site they can be purchased from and yes the HP bearings at the bottom of the page are tappered bearings. WW..
This is the post from last week:
If you want bearings that last ,get tappered bearings. One of the companys out there selling these are Wheel Bearings Direct, the manufacter doesn't sell retail direct to the public anymore but there is a ebay site that you can buy from. They have standard roller bearings for $69.99 and tappered HP bearings for $139.99 and these will last,These are made in the USA. Here is a email that I received from them the other day when I was inquiring about warrantys.
Quote:
The warranty is one year. The HP is the same warranty. What the difference is between the two is the HP runs a taper bearing inside and the standard has a ball type. The HP typically out lasts the standard 3 to 1. Thanks.: UnQuote
I have two friends with corvettes that run autocross and they say the HP is the best they have used, I bought on there recommendation. WW
http://stores.ebay.com/Wheel-Bearing...QQftidZ2QQtZkm
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
When I called them on the phone, they said they were an OEM manufacturer. What they did was take the stock bearings out and replace them with custom tapered bearings if wanted. But I don't see it listed on their catalog, and it's just for the rears.
Ok....don't wanna sound like a moron, but are the rear bearings on the C4 serviceable? I was under the assumption you had to replace the spindle assembly.
I need to replace the rears on my 89 and everything I have heard is stay with the AC Delco spindles. Everywhere I have looked they are at least 275.00 !! Are we talking about two different animals here? Don't mean to hijack this thread....but has anybody done this job recently? I have looked for recent posts/ links couldn't find any. Any input would be awesome. Thanks!
Funny they would advetise that they do.And yes the box did say Timken ,as did the casting.
I'm thinking we should buy one and either have CC pop it apart or have someone section it for a looksee inside.
What say everyone? Ten bucks each to my paypal account and I'll keep a running total in a thread in this section. Once we reach the magic number I'll pickup the part and get it to Kevin.
My $10 is already in....
It's a sealed unit. so you can NOT replace the seals and bearings, which probably cost all of $5
Pick up a cheap $12 manual, it will give you the basics, even if you don't service the car yourself, you'll better understand and not get taken by a mechanic.
Here is a email I sent to Wheel Bearing Inc. the company that makes the product and his response to my email.
Hi,
On ebay there is a vender selling your bearings for : (Chevrolet Corvette H.P. Wheel bearing 1984-1996)
under the name( Wheel Bearings Direct) . What I would like to know, is this HP a tappered bearing like he states because I don't see it listed in your online catalog? Thanks Wayne..
This is his reply:
Hi Wayne,
We do make this with a tappered bearing like he said. We make it with ball bearing also ( which is the one listed in the catalog). Thanks for your interest.
Hi,
This is his reply:
Hi Wayne,
