1974 high blower relay wiring?
Old 09-05-2007, 09:54 PM
BIGJIM13
BIGJIM13's Avatar
Default 1974 high blower relay wiring?
Hi
seem to be missing a connection on the high blower relay - I have the connector that is a three prong - but where does the single connection go
to?
Thanks
Old 09-05-2007, 10:15 PM
...Roger...
...Roger...'s Avatar
Originally Posted by BIGJIM13
Hi
to?
Thanks
Are your wire colors on the connector yellow-orange-lt blue ?
Old 09-05-2007, 10:22 PM
BIGJIM13
BIGJIM13's Avatar
actually just noticed only two wires going into the three wire connector - orange and dark blue - looks like the guy before me was up to something -
looks like I need a proper where the wires come from and where they go to lesson!
Old 09-05-2007, 10:24 PM
...Roger...
Do you have AC?
Old 09-05-2007, 10:26 PM
RunningMan373
RunningMan373's Avatar
Hey Dwinchs don't mean to step on your posts, but just did the job and i've got some good photos of it,,
The single connection in the back is ground, should be a black wire
The green wire goee through the fire wall to the fan speed switch on the consol to the fan "High" switch contact, it controls the fan relay in conjuction withthe black ground wire, closing it when it's selected
The orange wire is from constan +12V high current capable and fused on the drivers side,, see my post url address below
the purple wire is connected to the medium blue wire coming from the resistor pack back on the blower cover, the 10 guage wire. they can do this because there is a common batt. it then goes to the blower motor as it's single power lead, purple.
http://forums.corvetteforum.com/show....php?t=1787945
Old 09-05-2007, 10:31 PM
BIGJIM13
BIGJIM13's Avatar
a/c Yes
Old 09-05-2007, 10:35 PM
...Roger...
There you go Running Man has what you need.Nice write-up.
Old 09-05-2007, 10:40 PM
BIGJIM13
BIGJIM13's Avatar
Thanks
Old 09-05-2007, 10:52 PM
RunningMan373
Thanks DWnnchs,, didn't mean to step on your posts,, but just did the job recently and got some killer photos from it ..
It's reall a pretty simple circiut.. C.
Old 09-05-2007, 11:04 PM
...Roger...
Not a problem I cant find my 74 AC diagram so I was struggling a little anyway to find one.LOL Glad you stepped in.
Old 09-05-2007, 11:13 PM
BIGJIM13
BIGJIM13's Avatar
Guys - one more question - where to buy the connectors?
Old 09-05-2007, 11:25 PM
RunningMan373
You need the kind that has the cut-out spring part on the back. I don't have a source for them,, hopefully someone else does. A regular female connector would work,, w/o the springing cutout, you would just have to thread the wire through the plastic end, crimp it on the wire end and plug it in to the relay by itself,, then plug the black plastic end with the other two wires in it in. Use electrical grease/light bulb grease on the connectors for ease of removal in the future. If you go this route,, remove the small pastic insulator on the end of the new connector as it might cause fitting interferance. C.
If you need the whole plastic plug end with the wires in it, I would talk to a harness manufacturer, they could get you one with wire stubs attatched.
Old 09-06-2007, 07:31 AM
BIGJIM13
BIGJIM13's Avatar
Thanks
that what I need, the whole plastic plug end
Old 09-06-2007, 09:00 PM
71406's Avatar
I was able to find this connector at NAPA.
To 1974 high blower relay wiring?
Quick Reply: 1974 high blower relay wiring?
