C5 Parts for Sale/Wanted C5 Corvette Performance Parts, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements, OEM, Aftermarket
Sponsored by: C7 Carbon
C5 hid projection headlights www.vette-hid.com
Old 11-08-2005, 09:43 PM
NOT-MEE
NOT-MEE's Avatar
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Default C5 hid projection headlights www.vette-hid.com
GROUP PURCHASE ENDS DEC 5TH!!!!!! MIDNIGHT
A few people were having issues with paypal last night so i am going to extend it till the 7th. Checks or money order accepted also.
ALL COLORS In stock and ready for delivery
sales@vette-hid.com
www.vette-hid.com
10 set's LEFT available on the gp email or pm me for info
Here are a few pics of the New headlight system that There are DOT and SAE numbers on lenses so they are legal.
Stock light assembly is 1 lbs 14 oz each
T84 euro headlight assembly is 3.7 lbs each
New projection HID assembly is 3.05 lbs each
Retail is $1499
It is a complete plugnplay system.
The harness will allow for the HID low beam to stay on when high beams are on.
This is what you get
2 new projection replacement housings
2 new phillips ballasts
2 H1s HID Bulbs with all wiring
2 HIR1(9011) high beam bulb
here is some light output info
Stock Corvette C5 low beam bulb: 9006. Produces 1000 lumens.
New Corvette C5 low beam bulb: D1S. Produces 3200 lumens.
Stock Corvette C5 high beam bulb: 9005. Produces 1700 lumens.
New Corvette C5 high beam bulb: 9011. Produces 2500 lumens.
Complete Wiring harness with install instructions
3 year manufacture warranty!!!!!
CLICK HERE FOR LARGER PICS
INSTALL PIC'S AMD NIGHT PIC'S ARE ON LINK
After installing my set the dual harness isn't a bad idea,
It gives you the freedom to mount everything wherever you want.
Yes it is long on the passenger side so you have to cut and crimp it back together after making it shorter.
The ballasts have a long lead about 18 inches so custom hidden install would be easy.
I can make a custom harness for you if you like.
I mounted the ballasts under the headlights on front wheel-well.
Total Install time including mounting ballasts and modding harness is about 4 hours.
Remember to oil you adjusters.
Also do not over tighten the bolts that hold the headlight in place.
For all of those who say the system is too expensive.
The t84 Glaas euro HID kit with bulbs that is not legal costs $799.00.
Yes this system is more expensive than that!!!!!
Also the bulbs and ballast are hard to find on that kit if you have one fail.
This is projection system like the new c6 lights. Full DOT compliant meets all standards of MVSS108
If you burn out a bulb with our system they are the same as the new Audi, C6 Corvette and BMW.
You will get a new full swap out system all bulbs, ballasts, housings, and harnesses everything you need.
Here are some basic install instructions.
The corvette specific will be done hopefully tonight.
I having someone else write them because Mine sometimes get a little vague.
The short harness is for the passenger side.
thread bolts in the housings before you place them in car.
Makes it easier and keeps from damaging housings during install!!!!
Aim your headlights down as far as they will go to start with you can always bring them up.
When you look at all of the parts and remove your old lights they system installs pretty easy and very hard to make mistakes.
I used this site to do mine light install
we have done all of the soldering you need.
You need to decide where to mount ballast.
Grab power right at the fuse block.
Ground can be found next to battery.
donot force your adjusters when you feel it stop it is bottomed out they will brake.
Here is a few shots from last nights install
LINK TO INSTALL
You all have my phone number do not be afraid to use it. I have already helped two people today with their install.
keep a eye on thread c5 general for install hint's and precedures.
C5 general hid thread
Below is a few quotes from forum Members
Originally Posted by RPOZ4Z
Well I have to say that these new headlights ROCK!
I thought that the HID kit that I had in my euro T84 housing was nice, until I drove the car with the Vette-HID headlights!
the difference with these headlights is incredible!
I'll say it again, good job on this kit!
Originally Posted by BuckyThreadkiller
Hey! That's my car!
I have to say these exceed my wildest dreams. They went in night before last and I still can't believe how much superior they are to the stock lights. I have pics of the stock lights looking down my rural road and tonight I'll shoot pics with the new Vette-HIDs.
I'm amazed. It's a clean, white light doesn't seem to have the ricer blue tint to it. The cutoff line is remarkably sharp. The lows seem to be brighter than the stock hi-beams were and the light is much more even across the road surface.
I live out in the country with no street lights and lots of wildlife running across the roads. Do I think they're worth $1500? Every penny.
Call me very pleased! Thanks Brian!
Originally Posted by Jor-El
Hey guys, Brian was installing the black HID kit on my wife's Yellow C5. All I can say is WOW!!! The black kit looks awesome and function -- again WOW!!!
My wife has really bad astigmatism and thus has atrocious night vision. Before this kit was installed she wouldn't drive her Vette or any other vehicle we have at night, unless there was simply no alternative. She just cannot believe how much of a difference the kit made!! It's incredible!! She has much more confidence now driving her car at night. The kit works great and looks factory installed!! All of our C5s should have come from the factory with these!!! Now, I may just need to add a set for my Z06 and since Brian is testing a set for the C3, I may need a set for the Shark as well!!
Give these a try -- you won't be disappointed. I HIGHLY recommend them!!
Jor-El
Old 11-08-2005, 11:09 PM
wesZ06
wesZ06's Avatar
ttt...
Old 11-09-2005, 03:53 PM
NOT-MEE
NOT-MEE's Avatar
Cruise-In V Veteran
ttt
Old 11-09-2005, 04:32 PM
CrazyChris
CrazyChris's Avatar
What is the GP price or did I miss it?
Old 11-09-2005, 07:15 PM
cmeflyby
Support Corvetteforum!
cmeflyby's Avatar
Location: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
GP price? and is your black version available also, or only the chrome?
Old 11-09-2005, 07:31 PM
Airwolf
Airwolf's Avatar
Location: ********************* Florida's Space Coast *********************
GP Price???
Old 11-09-2005, 08:39 PM
servohead
servohead's Avatar
Last I saw this upgrade cost $1500 bucks. Yeah. Thanks. Just a little over what I can throw at headlights.....
Old 11-09-2005, 08:48 PM
Goonie
Goonie's Avatar
lol yeah.. just buy some "blue" bulbs at napa and u get a similar effect
Old 11-09-2005, 09:05 PM
Billy182
Billy182's Avatar
I already have top shelf D2-S bulbs and Philips ballasts with Euro glass stock lenses, so all I would need would be the new lenses and projectors if they fit D2-S bulbs.
Thanks,
Bill
Old 11-09-2005, 09:15 PM
2KREDVert
2KREDVert's Avatar
$1500 for headlights............ Yea right, I have a bridge to sell you!!!!!!!!!
Old 11-09-2005, 11:28 PM
NOT-MEE
NOT-MEE's Avatar
Cruise-In V Veteran
Thanks,
Bill
They are fitted for d1s bulbs
Old 11-09-2005, 11:29 PM
NOT-MEE
NOT-MEE's Avatar
Cruise-In V Veteran
before you bash a price you might want to ask what gp price is.
Old 11-09-2005, 11:34 PM
Moval49er
Moval49er's Avatar
At least three in this thread already have - so what is it?
Old 11-09-2005, 11:38 PM
NOT-MEE
NOT-MEE's Avatar
Cruise-In V Veteran
Ok there is a minimum advertised price policy with the product I cannot post GP price I have 60 kits in stock.
Old 11-09-2005, 11:49 PM
NOT-MEE
NOT-MEE's Avatar
Cruise-In V Veteran
sent pm's to everyone
Old 11-10-2005, 02:26 AM
Rollin Black
Rollin Black's Avatar
Okay, I'll bite, PM me the GP price.
Perry
Old 11-10-2005, 02:43 AM
BickyDhadwal
BickyDhadwal's Avatar
pm me with a group purchase price aswell...they look incredible...worth the $$$ but im not sure if i can afford them yet...
and could you also give me a price for some quality xenon type bulbs...low and high beam...thanks
To C5 hid projection headlights www.vette-hid.com
Old 11-10-2005, 07:27 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Please PM GP price.
Old 11-10-2005, 07:43 AM
NOT-MEE
NOT-MEE's Avatar
Cruise-In V Veteran
PM's sent
Old 11-10-2005, 10:04 AM
JTE
JTE's Avatar
CI 4-7, 9 & 10 Veteran
Interested in the GP price. PM please.
Quick Reply: C5 hid projection headlights www.vette-hid.com
