Oil life reset...?
I need help resetting my oil life display. I followed the directions in the manual and all I get is display showing (OIL LIFE_ _ _ %.)
What am I doing wrong ?? Chuck :flag: |
Ignition on, car not running. Go to oil life % display on the dic and depress the gas pedal to the floor 4 times.
Make sure that the ignition is "ON" and the engine is "OFF". :yesnod:
Its all done with the DIC and the Reset buttom. |
For my 1999, key on, depress gas pedal 3 times. Doesn't matter what DIC is showing on mine. :cheers:
I hold my reset button down until the _ _ _% disappears and is replaced with the 100% indicator.
:iagree: Same thing I do on my 98. |
Same for my 2000.
No need to hit the gas pedal, just the reset button. |
I think BOTH ways will work. Gas pedal or reset button. Reset button is a little quicker.
Make sure that the ignition is "ON" and the engine is "OFF". then one day while driving, i pressed the "reset" and held it down, and it went to 100%!!! so just something to try. hope this helped. |
