Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-27-2004, 11:36 AM   #1
shnooks-formula1
CF Member
Default Oil life reset...?
I need help resetting my oil life display. I followed the directions in the manual and all I get is display showing (OIL LIFE_ _ _ %.)
What am I doing wrong ??
Chuck
shnooks-formula1 is offline   Reply With Quote
Old 09-27-2004, 11:59 AM   #2
C5JONNY
CF Senior Member
C5JONNY's Avatar
Send a message via AIM to C5JONNY
Ignition on, car not running. Go to oil life % display on the dic and depress the gas pedal to the floor 4 times.
C5JONNY is offline   Reply With Quote
Old 09-27-2004, 12:28 PM   #3
BAND1T
CF Senior Member
BAND1T's Avatar
Make sure that the ignition is "ON" and the engine is "OFF".
__________________
TJ
'00 Navy/Gray coupe
My Car!
BAND1T is offline   Reply With Quote
Old 09-27-2004, 02:26 PM   #4
50 4Ever
Wil Cooksey #256
Support Corvetteforum!
50 4Ever's Avatar
Quote:
Not on a 2003
Its all done with the DIC and the Reset buttom.
50 4Ever is offline   Reply With Quote
Old 09-27-2004, 02:51 PM   #5
Rex99Coupe
CF Senior Member
Rex99Coupe's Avatar
For my 1999, key on, depress gas pedal 3 times. Doesn't matter what DIC is showing on mine.
Rex99Coupe is offline   Reply With Quote
Old 09-27-2004, 06:19 PM   #6
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
I hold my reset button down until the _ _ _% disappears and is replaced with the 100% indicator.
__________________
2003 Electron Blue Coupe A4 (Born on 1/14/2003)
NCM Founding Member #828
24 Year NCM Member (1990-2014)
NCM Grand Opening Participant - 1994
NCM 5th Anniversary Participant - 1999
Corvette 50th Anniversary Participant - 2003
NCM 15th Anniversary Participant - 2009
Vetteman Jack is offline   Reply With Quote
Old 09-27-2004, 06:22 PM   #7
FDA
CF Senior Member
FDA's Avatar
Fielding D. Alderman
Quote:
Same thing I do on my 98.
FDA is offline   Reply With Quote
Old 09-27-2004, 06:48 PM   #8
Len16
CF Senior Member
Same for my 2000.
No need to hit the gas pedal, just the reset button.
__________________
Hartford, CT.
2010 Silver Coupe
Len16 is offline   Reply With Quote
Old 09-27-2004, 10:05 PM   #9
davette
CF Senior Member
davette's Avatar
I think BOTH ways will work. Gas pedal or reset button. Reset button is a little quicker.
davette is offline   Reply With Quote
Old 09-28-2004, 06:58 PM   #10
C5 KIDD
CF Senior Member
Cruise-In VI Veteran
C5 KIDD's Avatar
i tried that way and for some reason it wouldnt work on my car. i ended up just leaving it because it wouldnt change. then i got the "change oil" message. still couldnt get it to go to 100%.
then one day while driving, i pressed the "reset" and held it down, and it went to 100%!!!
so just something to try. hope this helped.
C5 KIDD is offline   Reply With Quote
Reload this Page Oil life reset...?
Tags
03, 1998, 2000, 2003, 2004, c5, corvette, corvetteforum, corvwtte, gauge, guage, life, oil, reset, resetting
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
