Free Flow exhaust, good or bad??
My floor is hot and I would like to up the performance of my 89. It was suggested that I get a new y-pipe with no cats and that I get a newer main cat or just hollow out what I have. I hear that a better flow isn't always good, supposedly I need some back pressure. I guess there's two schools of thought on this subject. I would like your feedback. Will removing my pre-cats cool the floor?? What are some of my options when it comes to getting a better flowing exhaust?? My engine is stock, although I wouldn't mind adding a chip. How much HP can I get from a free flow exhaust??? What do I do with sensor on pre-cats??
cant speak for precats, because my vette doesn't have em... but if your floor is getting hot, you're precats (or cats) are probably clogged... just putting on new ones or high flow ones would free up some HP
Back pressure is your enemy not your friend.
As David Vizzard puts it in his books on SBCs, you just need to tune the engine for the reduced back pressure. Also install an AFPR so you can add a little fuel at WOT when you go to a cleaner exhaust system. |
the L98 will see about 15-25hp freed up by eliminating the chokehold from the factory exhaust. Long tube headers (re-locate the o2 sensor bung to the passenger side collector @ 11:00 position), front Y-pipe w/o pre-cats, gut your main cat (be sure to install a "test pipe" thru it), and a decent cat-back (or muffler elims) will get you on the high side of +25hp.....alos your vette will sound a helluva lot better. i agree with the previous post about the probability that your pre-cats are clogged (floor heat). be prepared for a nice SOTP kick.
:iagree:
And would like to add header primary length and diameter also plays a roll. I can't find the dyno sheet I got with my car (88) but with free mods and headers it was putting down either 340 or 320 RW ft lbs at 3000 RPM with true duals and no cats. |
Upstate,
What else did you do to your car to get 340??? |
Bradvette,
Can I put a completely free flow exhaust with a chip?? How much HP can I get with that?? |
65Z01,
Any guess on how many horses I can get with a free flow exhaust and a chip from an 89 stock engine??? |
As David Vizzard puts it in his books on SBCs, you just need to tune the engine for the reduced back pressure. Also install an AFPR so you can add a little fuel at WOT when you go to a cleaner exhaust system. I showed this pic yesterday on another thread of my handywork with my pre-cats..here it is again. :cheers: http://www.pixfiles.net/pix/336793284556831609.jpg |
All free mods and some extra's here
"AFPR"... is that a fuel pressure regulator? How do you tune them to the right amount?
I gained about 15-20chp from doing the front Y, RT cat and TPIS cat-back. Vic-89 had the same exhaust setup and picked up another 20chp when he installed 1 3/4" FL coated headers.
Since I have dyno data with A/F at WOT along with stock O2 sensor readings down the 1/4 mile I can tune my AFPR from the stock O2 sensor using my scanner. If you don't have such data and can get consistent trap speed readings you can tune fuel flow for max trap speed, either at the strip or using a G-tech. I prefer to use an AFPR for tuning as even a custom chip must be burned each time you make an air flow mod whereas you simply bump fuel pressure with the AFPR. |
Originally Posted by jzvette
Upstate,
What else did you do to your car to get 340??? The previous owner of my car cut a best of 13.2xx with that combo running without an air cleaner. |
Since I have dyno data with A/F at WOT along with stock O2 sensor readings down the 1/4 mile I can tune my AFPR from the stock O2 sensor using my scanner. If you don't have such data and can get consistent trap speed readings you can tune fuel flow for max trap speed, either at the strip or using a G-tech. I prefer to use an AFPR for tuning as even a custom chip must be burned each time you make an air flow mod whereas you simply bump fuel pressure with the AFPR. Your stock O2 sensor data is useless at WOT. The narrow band O2 sensor simply defaults to "rich" at WOT, and the ECM goes into open loop and ignores the O2 signal & runs on preprogrammed look-up tables based on TP angle, coolant temp, and engine load or airflow. OEM GM type O2 sensors can only detect air/fuel mixtures in a very narrow window that is centered at 14.7:1. Any stock GM car runs much closer to 12:1 a/f ratio at WOT. A wideband O2 sensor and accompanying aftermarket ECM are needed to run in closed loop at WOT. Bumping fuel pressure richens the mixture across the RPM range, which isn't good for idle quality, emissions, catalyst life or low RPM cruise. It may or may not help your E.T., depending on your existing PROM settings. |
