Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-06-2004, 04:58 AM   #1
jzvette
CF Senior Member
jzvette's Avatar
Default Free Flow exhaust, good or bad??
My floor is hot and I would like to up the performance of my 89. It was suggested that I get a new y-pipe with no cats and that I get a newer main cat or just hollow out what I have. I hear that a better flow isn't always good, supposedly I need some back pressure. I guess there's two schools of thought on this subject. I would like your feedback. Will removing my pre-cats cool the floor?? What are some of my options when it comes to getting a better flowing exhaust?? My engine is stock, although I wouldn't mind adding a chip. How much HP can I get from a free flow exhaust??? What do I do with sensor on pre-cats??
jzvette is offline   Reply With Quote
Old 09-06-2004, 10:35 AM   #2
mikey whipreck
CF Senior Member
mikey whipreck's Avatar
cant speak for precats, because my vette doesn't have em... but if your floor is getting hot, you're precats (or cats) are probably clogged... just putting on new ones or high flow ones would free up some HP
mikey whipreck is offline   Reply With Quote
Old 09-06-2004, 11:08 AM   #3
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
Back pressure is your enemy not your friend.
As David Vizzard puts it in his books on SBCs, you just need to tune the engine for the reduced back pressure.
Also install an AFPR so you can add a little fuel at WOT when you go to a cleaner exhaust system.
__________________
My 1988 Z01 #65 Site
65Z01 is offline   Reply With Quote
Old 09-06-2004, 11:17 AM   #4
Red Tornado
CF Senior Member
Red Tornado's Avatar
the L98 will see about 15-25hp freed up by eliminating the chokehold from the factory exhaust. Long tube headers (re-locate the o2 sensor bung to the passenger side collector @ 11:00 position), front Y-pipe w/o pre-cats, gut your main cat (be sure to install a "test pipe" thru it), and a decent cat-back (or muffler elims) will get you on the high side of +25hp.....alos your vette will sound a helluva lot better. i agree with the previous post about the probability that your pre-cats are clogged (floor heat). be prepared for a nice SOTP kick.
Red Tornado is offline   Reply With Quote
Old 09-06-2004, 11:23 AM   #5
Upstate
CF Senior Member
Upstate's Avatar
And would like to add header primary length and diameter also plays a roll. I can't find the dyno sheet I got with my car (88) but with free mods and headers it was putting down either 340 or 320 RW ft lbs at 3000 RPM with true duals and no cats.
Upstate is offline   Reply With Quote
Old 09-06-2004, 12:50 PM   #6
jzvette
CF Senior Member
jzvette's Avatar
Upstate,
What else did you do to your car to get 340???
Old 09-06-2004, 12:51 PM   #7
jzvette
CF Senior Member
jzvette's Avatar
Bradvette,
Can I put a completely free flow exhaust with a chip?? How much HP can I get with that??
Old 09-06-2004, 12:54 PM   #8
jzvette
CF Senior Member
jzvette's Avatar
65Z01,
Any guess on how many horses I can get with a free flow exhaust and a chip from an 89 stock engine???
Old 09-06-2004, 01:29 PM   #9
skateparkdave
CF Senior Member
St. Jude Donor '05-'06
skateparkdave's Avatar
Just need to tune for free flow.
I showed this pic yesterday on another thread of my handywork with my pre-cats..here it is again.
http://www.pixfiles.net/pix/336793284556831609.jpg
skateparkdave is offline   Reply With Quote
Old 09-06-2004, 01:34 PM   #10
cdnguyred88
CF Senior Member
cdnguyred88's Avatar
All free mods and some extra's here
__________________
02 Triple Black Auto Vert, Maggie, B&B exhaust
Red '88 Auto coupe. 247.5 rwhp, 341.4 Torque. 1.6 r.r's, Hedman headers,
air pump elim., 180 stat., x pipe, k&n , cut lid, no frisbee, massaged Heads, ported Plenum
cdnguyred88 is online now   Reply With Quote
Old 09-06-2004, 01:35 PM   #11
mikey whipreck
CF Senior Member
"AFPR"... is that a fuel pressure regulator? How do you tune them to the right amount?
Old 09-06-2004, 01:49 PM   #12
65Z01
CF Senior Member
65Z01's Avatar
I gained about 15-20chp from doing the front Y, RT cat and TPIS cat-back. Vic-89 had the same exhaust setup and picked up another 20chp when he installed 1 3/4" FL coated headers.
Since I have dyno data with A/F at WOT along with stock O2 sensor readings down the 1/4 mile I can tune my AFPR from the stock O2 sensor using my scanner.
If you don't have such data and can get consistent trap speed readings you can tune fuel flow for max trap speed, either at the strip or using a G-tech.
I prefer to use an AFPR for tuning as even a custom chip must be burned each time you make an air flow mod whereas you simply bump fuel pressure with the AFPR.
__________________
Old 09-06-2004, 02:15 PM   #13
Upstate
CF Senior Member
Upstate's Avatar
Quote:
Originally Posted by jzvette
Upstate,
My old setup is nearly identical to cdnguyred88's setup, with the addition of an aftermarket converter, the AIR pump, and stock RR's. The dyno numbers are damn near identical to boot.
The previous owner of my car cut a best of 13.2xx with that combo running without an air cleaner.
Old 10-08-2004, 04:06 AM   #14
emissions_guru
Junior Member
Your stock O2 sensor data is useless at WOT. The narrow band O2 sensor simply defaults to "rich" at WOT, and the ECM goes into open loop and ignores the O2 signal & runs on preprogrammed look-up tables based on TP angle, coolant temp, and engine load or airflow.
OEM GM type O2 sensors can only detect air/fuel mixtures in a very narrow window that is centered at 14.7:1. Any stock GM car runs much closer to 12:1 a/f ratio at WOT. A wideband O2 sensor and accompanying aftermarket ECM are needed to run in closed loop at WOT.
Bumping fuel pressure richens the mixture across the RPM range, which isn't good for idle quality, emissions, catalyst life or low RPM cruise. It may or may not help your E.T., depending on your existing PROM settings.
emissions_guru is offline   Reply With Quote
Reload this Page Free Flow exhaust, good or bad??
Tags
89, aftermarket, bad, catback, corvette, custom, engine, exhaust, flow, free, freeflow, good, high, life, performance, yahoo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
*Borla stinger exhaust 86-91 round tips. 1k miles mos90 C4 Parts for Sale/Wanted 10 09-12-2005 09:31 AM
TPI Coolant Bypass???? ChiMan C4 Tech/Performance 12 04-04-2003 07:26 PM
throttle body bypass? do they work? r15752 C4 Tech/Performance 24 03-20-2003 03:02 PM
Free heads and cam install! CJS C5 Tech 16 07-14-2002 09:43 PM
Open Exhaust = Burned Valves.... True/False? Marcho Polo C4 Tech/Performance 12 11-27-2001 03:09 PM
JUST COMPLETED MODS TO MY 86 (exhaust, gears and rear suspension bushings) Cruz 86 C4 Tech/Performance 9 08-28-2001 05:53 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
