ZO6 throttle body size?
WHat is the ZO6 factory throttle body size?
Re: ZO6 throttle body size? (steve40th)
75 mm on the LS6, same as LS1 and truck versions.
BTW, Z06 is the car option, LS6 is the engine in it. |
Re: ZO6 throttle body size? (OldSStroker)
On the new 2005 C6 LS2 new 90mm TB
75 mm on the LS6, same as LS1 and truck versions. |
Re: ZO6 throttle body size? (2000Firehawk)
On the new 2005 C6 LS2 new 90mm TB |
On the new 2005 C6 LS2 new 90mm TB News to me. What's your source? Seems like overkill for 400hp 6.0L Here is the whole powertrain info with the 90mm TB listed on the corvette museum website as well: http://www.corvettemuseum.com/specs/...wertrain.shtml [Modified by kewlbrz, 9:11 PM 1/2/2004] |
:iagree: :thumbs:
90mm I know that most of the blown factory motors use large throttle bodys but naturally asperated 90mm , Sounds like when I was younger and got alot of 600cfm carbs for cheap because every guy with a 327 thought they needed a 850 double pumper to go fast. I got a small block tunnel ram with two 1150 dominators and nos fogger . :D :D :D
Re: ZO6 throttle body size? (SQEZN BI)
You're right about too much aftermarket carburation in the old days, but I would expect that GM did its homework on this one, especially since it's a change from a number of years of smaller TB's.
Re: ZO6 throttle body size? (kewlbrz)
On the new 2005 C6 LS2 new 90mm TB News to me. What's your source? Seems like overkill for 400hp 6.0L This is common knowledge from many car magazines and media articles now out about the C6. Here is the whole powertrain info with the 90mm TB listed on the corvette museum website as well: http://www.corvettemuseum.com/specs/...wertrain.shtml I read it in a couple of non-GM announcements, but I'm still skeptical of a 90mm on a 400 hp 6.0. That's 44% more flow area than the current LS1/LS6 TB. Now that sounds about right for the reported 500 hp Z06 car for 2006. Once or twice in the past media folks have misprinted specs and they have become "common knowledge". Count me as a skeptic so far. Thanks for the link. [Modified by kewlbrz, 9:11 PM 1/2/2004] [Modified by OldSStroker, 11:49 AM 1/8/2004] |
stop strokin' it's a reality. The 90 MM throttlebody was part of the Detroit presentation concerning the C6. You can view and HEAR the comments on the webcast simply by going the Chevrolet website and working to the Corvette links, and/or going to the C6 section on this forum and follow the threads referencing the webcast
WOW F*&^ing WOW!!!!!!!!!!!!!!!!!!!!!!
What a FREAKIN CAR !!!!!!!!!!!!!!!! Look out COBRAS :party: :party: :party: |
