ZO6 throttle body size?
Old 01-02-2004, 12:26 AM
steve40th
steve40th's Avatar
St. Jude Donor '03 & '05
Default ZO6 throttle body size?
WHat is the ZO6 factory throttle body size?
Old 01-02-2004, 10:18 AM
OldSStroker
OldSStroker's Avatar
Default Re: ZO6 throttle body size? (steve40th)
75 mm on the LS6, same as LS1 and truck versions.
BTW, Z06 is the car option, LS6 is the engine in it.
Old 01-02-2004, 10:31 AM
2000Firehawk
2000Firehawk's Avatar
Default Re: ZO6 throttle body size? (OldSStroker)
On the new 2005 C6 LS2 new 90mm TB
Old 01-02-2004, 06:16 PM
V8_Club
V8_Club's Avatar
:yesnod:
Old 01-02-2004, 09:38 PM
OldSStroker
Default Re: ZO6 throttle body size? (2000Firehawk)
News to me. What's your source? Seems like overkill for 400hp 6.0L
Old 01-02-2004, 09:56 PM
kewlbrz
kewlbrz's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
This is common knowledge from many car magazines and media articles now out about the C6.
Here is the whole powertrain info with the 90mm TB listed on the corvette museum website as well:
http://www.corvettemuseum.com/specs/...wertrain.shtml
[Modified by kewlbrz, 9:11 PM 1/2/2004]
Old 01-02-2004, 11:48 PM
LittleBoyBlu99
LittleBoyBlu99's Avatar
:iagree: :thumbs:
Old 01-06-2004, 11:22 PM
SQEZN BI
SQEZN BI's Avatar
90mm I know that most of the blown factory motors use large throttle bodys but naturally asperated 90mm , Sounds like when I was younger and got alot of 600cfm carbs for cheap because every guy with a 327 thought they needed a 850 double pumper to go fast. I got a small block tunnel ram with two 1150 dominators and nos fogger . :D :D :D
Old 01-07-2004, 08:52 AM
Tree
Tree's Avatar
Default Re: ZO6 throttle body size? (SQEZN BI)
You're right about too much aftermarket carburation in the old days, but I would expect that GM did its homework on this one, especially since it's a change from a number of years of smaller TB's.
Old 01-07-2004, 10:05 AM
OldSStroker
Default Re: ZO6 throttle body size? (kewlbrz)
I read it in a couple of non-GM announcements, but I'm still skeptical of a 90mm on a 400 hp 6.0. That's 44% more flow area than the current LS1/LS6 TB. Now that sounds about right for the reported 500 hp Z06 car for 2006.
Once or twice in the past media folks have misprinted specs and they have become "common knowledge". Count me as a skeptic so far.
Thanks for the link.
[Modified by OldSStroker, 11:49 AM 1/8/2004]
Old 01-07-2004, 03:01 PM
2ndVette
2ndVette's Avatar
stop strokin' it's a reality. The 90 MM throttlebody was part of the Detroit presentation concerning the C6. You can view and HEAR the comments on the webcast simply by going the Chevrolet website and working to the Corvette links, and/or going to the C6 section on this forum and follow the threads referencing the webcast
Old 01-07-2004, 03:23 PM
dv05
dv05's Avatar
WOW F*&^ing WOW!!!!!!!!!!!!!!!!!!!!!!
What a FREAKIN CAR !!!!!!!!!!!!!!!!
Look out COBRAS :party: :party: :party:
To ZO6 throttle body size?
Quick Reply: ZO6 throttle body size?
