I need a vacuum port diagram for a holley 4160 600cfm...
It's an electric choke, vacuum secondary 4160 600cfm holley squarebore. I need to know where my vacuum advance connects and were my PCV connects. Thanks guys!!
Re: I need a vacuum port diagram for a holley 4160 600cfm... (TIMSPEED)
you are keeping the choke? it fits under the hood with the choke? you must have a low intake if so..... :confused: i had to mill the airhorn off to fit under my hood.....good luck. :cheers:
Re: I need a vacuum port diagram for a holley 4160 600cfm... (yoslambo1@cs.com)
EDIT: OOPS! Mod's can you put this in C3 Corvette please...I must have hit the wrong button. Sorry! :bb
[Modified by TIMSPEED, 10:34 AM 3/13/2003] |
sorry i cant help....my engine builder made me remove the vaccume advance in case of detination! :eek: :confused:
If it's a later model 4160, there should be 2 small ports on the passenger's side front. The upper port (on the metering block by the idle mixture screw) is for ported vacuum advance. Below that, on the base plate, is the same size port that is unported manifold vacuum. Towards the rear of the carb on the sam side is a large port for PCV.
