I need a vacuum port diagram for a holley 4160 600cfm...
Old 03-13-2003, 01:17 PM
TIMSPEED
TIMSPEED's Avatar
Default I need a vacuum port diagram for a holley 4160 600cfm...
It's an electric choke, vacuum secondary 4160 600cfm holley squarebore. I need to know where my vacuum advance connects and were my PCV connects. Thanks guys!!
Old 03-13-2003, 01:27 PM
yoslambo1@cs.com
yoslambo1@cs.com's Avatar
Default Re: I need a vacuum port diagram for a holley 4160 600cfm... (TIMSPEED)
you are keeping the choke? it fits under the hood with the choke? you must have a low intake if so..... :confused: i had to mill the airhorn off to fit under my hood.....good luck. :cheers:
Old 03-13-2003, 01:33 PM
TIMSPEED
TIMSPEED's Avatar
Default Re: I need a vacuum port diagram for a holley 4160 600cfm... (yoslambo1@cs.com)
EDIT: OOPS! Mod's can you put this in C3 Corvette please...I must have hit the wrong button. Sorry! :bb
[Modified by TIMSPEED, 10:34 AM 3/13/2003]
Old 03-13-2003, 01:37 PM
yoslambo1@cs.com
sorry i cant help....my engine builder made me remove the vaccume advance in case of detination! :eek: :confused:
Old 03-13-2003, 08:59 PM
Vetterodder
Vetterodder's Avatar
If it's a later model 4160, there should be 2 small ports on the passenger's side front. The upper port (on the metering block by the idle mixture screw) is for ported vacuum advance. Below that, on the base plate, is the same size port that is unported manifold vacuum. Towards the rear of the carb on the sam side is a large port for PCV.
To I need a vacuum port diagram for a holley 4160 600cfm...
Quick Reply: I need a vacuum port diagram for a holley 4160 600cfm...
