1979 VIN Door Jamb Sticker. Need Info
I recently ordered and received today a blank door jamb sticker for my 1979. The original was torn off by a painter two years ago. I know my VIN but I forget the other info for a 1979
-is the Date 11/78 such as for November 1978? -what is the GVWR? -what is the GAWR FRT? -what is GAWR RR? If someone with a 1979 could take a peek at their sticker and give me this info it would be very much appreciated. Also care to speculate on the font and font size used? https://temp.corvetteforum.net/c3/pa...ticker_003.jpg |
Re: 1979 VIN Door Jamb Sticker. Need Info (Ed T)
Ed, no they have not arrived. But there is postal service tomorrow! Perhaps Santa will come!! And the Best to You and Yours :) .
Paul |
Re: 1979 VIN Door Jamb Sticker. Need Info (paul79)
*grumble* ill have to make a trip to the storage shed. but ok. :lol: i need to take a look at her anyway. ill go start up the truck.
Date 12/78
GVWR 1424LB 1871KG GVWR FRT 1859LB 844KG GVWR RR 2265LB 1028KG Serial No of car Pass Car Consumer information tables AED It looks like it's all in courier new font? 8 or 10 |
Re: 1979 VIN Door Jamb Sticker. Need Info (Yellow79)
ok heres what i got:
1.the date is as 00/00, mine was05/79 2.GVWR is listed as 4104 lb ( god i hope thats not the weight) with a 1862 kg reading below 3. GVWR FRT is 1852 lb, again with a 891 kg listed below that 4. GVWR RR is 2252. again a kg weight listed below that. fonts i am not good at. the lettering is 1/8 inch exact. good luck wish i couldv given you more |
Re: 1979 VIN Door Jamb Sticker. Need Info (killain)
Killain,
You may have mis-read the Gross Vehicle Weight: 1871kg is about 4116lbs. |
Here ya go, hope this helps.. Right out of the 1978-79 NCRS Tech Manual.
http://www.hotrodder.com\nick\postings\id.jpg [Modified by SLICKMAN, 9:42 PM 12/23/2002] [Modified by SLICKMAN, 9:43 PM 12/23/2002] |
Yeah, it must be 871KG
Thanks. Now I have to find a typewriter. Anyone besides me remember those ;) ?
Okay, lets try this again
Here ya go, hope this helps.. Right out of the 1978-79 NCRS Tech Manual. http://www.hotrodder.com/nick/postings/id.jpg [Modified by SLICKMAN, 9:45 PM 12/23/2002] |
Re: 1979 VIN Door Jamb Sticker. Need Info (SLICKMAN)
Many thanks! I printed that out. But 5250 lbs?? This is not a Lincoln Navigator ;) .
[Modified by paul79, 10:35 PM 12/23/2002] |
That was with Buba in the car ;)
I have a 79.
I'll take a picture of my sticker and post it here ASAP. |
Paul, there is another sticker right below the one with weights on my car?
GVWR is the gross vehicle weight rating. Maximum permissable load, including car, fuel, passengers, luggage.
The others are max for f and r axles |
I got the info. Thanks to all respondents!
Paul,
Where did you get that sticker?? The same thing happened to me when I had my car repainted and it was bead-blasted off. I have looked everywhere for another sticker, but I was able to find the only the tire sticker. |
Re: 1979 VIN Door Jamb Sticker. Need Info (79Shark)
E-mail me and I will give you the source.
*Edit*-BTW, where did you get the tire info decal? [Modified by paul79, 12:53 AM 12/26/2002] |
