1979 VIN Door Jamb Sticker. Need Info
Old 12-23-2002, 06:07 PM
Paul L
Paul L's Avatar
Default 1979 VIN Door Jamb Sticker. Need Info
I recently ordered and received today a blank door jamb sticker for my 1979. The original was torn off by a painter two years ago. I know my VIN but I forget the other info for a 1979
-is the Date 11/78 such as for November 1978?
-what is the GVWR?
-what is the GAWR FRT?
-what is GAWR RR?
If someone with a 1979 could take a peek at their sticker and give me this info it would be very much appreciated. Also care to speculate on the font and font size used?
Old 12-23-2002, 07:15 PM
Paul L
Paul L's Avatar
Default Re: 1979 VIN Door Jamb Sticker. Need Info (Ed T)
Ed, no they have not arrived. But there is postal service tomorrow! Perhaps Santa will come!! And the Best to You and Yours :) .
Paul
Old 12-23-2002, 08:44 PM
Yellow79
Yellow79's Avatar
Default Re: 1979 VIN Door Jamb Sticker. Need Info (paul79)
*grumble* ill have to make a trip to the storage shed. but ok. :lol: i need to take a look at her anyway. ill go start up the truck.
Old 12-23-2002, 09:05 PM
killain
Support Corvetteforum!
killain's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Date 12/78
GVWR 1424LB
1871KG
GVWR FRT 1859LB
844KG
GVWR RR 2265LB
1028KG
Serial No of car Pass Car
Consumer information tables AED
It looks like it's all in courier new font? 8 or 10
Old 12-23-2002, 09:11 PM
Yellow79
Yellow79's Avatar
Default Re: 1979 VIN Door Jamb Sticker. Need Info (Yellow79)
ok heres what i got:
1.the date is as 00/00, mine was05/79
2.GVWR is listed as 4104 lb ( god i hope thats not the weight) with a 1862 kg reading below
3. GVWR FRT is 1852 lb, again with a 891 kg listed below that
4. GVWR RR is 2252. again a kg weight listed below that.
fonts i am not good at. the lettering is 1/8 inch exact. good luck wish i couldv given you more
Old 12-23-2002, 09:38 PM
Paul L
Paul L's Avatar
Default Re: 1979 VIN Door Jamb Sticker. Need Info (killain)
Killain,
You may have mis-read the Gross Vehicle Weight: 1871kg is about 4116lbs.
Old 12-23-2002, 09:41 PM
SLICKMAN
SLICKMAN's Avatar
Here ya go, hope this helps.. Right out of the 1978-79 NCRS Tech Manual.
[Modified by SLICKMAN, 9:42 PM 12/23/2002]
[Modified by SLICKMAN, 9:43 PM 12/23/2002]
killain
killain's Avatar
Oldtimer
Yeah, it must be 871KG
Paul L
Paul L's Avatar
Thanks. Now I have to find a typewriter. Anyone besides me remember those ;) ?
Old 12-23-2002, 09:44 PM
SLICKMAN
SLICKMAN's Avatar
Okay, lets try this again
[Modified by SLICKMAN, 9:45 PM 12/23/2002]
Old 12-23-2002, 10:30 PM
Paul L
Paul L's Avatar
Default Re: 1979 VIN Door Jamb Sticker. Need Info (SLICKMAN)
Many thanks! I printed that out. But 5250 lbs?? This is not a Lincoln Navigator ;) .
[Modified by paul79, 10:35 PM 12/23/2002]
Old 12-24-2002, 05:50 AM
SLICKMAN
SLICKMAN's Avatar
That was with Buba in the car ;)
Old 12-24-2002, 08:39 AM
Adam Wartell
Adam Wartell's Avatar
I have a 79.
I'll take a picture of my sticker and post it here ASAP.
Old 12-24-2002, 01:31 PM
killain
killain's Avatar
Oldtimer
Paul, there is another sticker right below the one with weights on my car?
Old 12-24-2002, 02:13 PM
a454corvette
a454corvette's Avatar
GVWR is the gross vehicle weight rating. Maximum permissable load, including car, fuel, passengers, luggage.
The others are max for f and r axles
Old 12-24-2002, 08:21 PM
Paul L
Paul L's Avatar
I got the info. Thanks to all respondents!
Old 12-25-2002, 11:18 AM
79Shark
79Shark's Avatar
Paul,
Where did you get that sticker?? The same thing happened to me when I had my car repainted and it was bead-blasted off. I have looked everywhere for another sticker, but I was able to find the only the tire sticker.
Old 12-25-2002, 02:31 PM
Paul L
Paul L's Avatar
Default Re: 1979 VIN Door Jamb Sticker. Need Info (79Shark)
E-mail me and I will give you the source.
*Edit*-BTW, where did you get the tire info decal?
[Modified by paul79, 12:53 AM 12/26/2002]
To 1979 VIN Door Jamb Sticker. Need Info
Quick Reply: 1979 VIN Door Jamb Sticker. Need Info
