Install of Dyna Mod HEI Module
Has anyone installed one of these modules in thier HEI Distributor????
Any hints of beat install????? Help............. LETS HEAR IT..... thanks tony :confused: :smash: :smash: :smash: |
Re: Install of Dyna Mod HEI Module (oldace84)
I installed the Accel modual in my 84, no problems after three years. Only tip is to be sure and use that little tube of grease they give you on the bottom side of the modual. Good luck 84 CF 91 ZR-1
Re: Install of Dyna Mod HEI Module (vettl83)
Thanks for the tip.....did you remove the distruitor, or install with it in the car?????
Let me know..OK????OK!!! THANKS TONY :smash: |
Thanks for the tip.....did you remove the distruitor, or install with it in the car????? |
Re: Install of Dyna Mod HEI Module (Hole-Shot)
Thanks again...
tony :cheers: |
i installed an accell module.
be careful with the wire connectors to the distributor, mine were very brittle after years of heat. plastic in that condition breaks very easily. |
