Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-23-2002, 11:35 PM   #1
oldace84
CF Senior Member
St. Jude Donor '04 & '05
oldace84's Avatar
Default Install of Dyna Mod HEI Module
Has anyone installed one of these modules in thier HEI Distributor????
Any hints of beat install????? Help.............
LETS HEAR IT.....
thanks
tony
:confused: :smash: :smash: :smash:
oldace84 is offline   Reply With Quote
Old 09-24-2002, 02:09 AM   #2
vettl83
CF Senior Member
vettl83's Avatar
Default Re: Install of Dyna Mod HEI Module (oldace84)
I installed the Accel modual in my 84, no problems after three years. Only tip is to be sure and use that little tube of grease they give you on the bottom side of the modual. Good luck 84 CF 91 ZR-1
vettl83 is offline   Reply With Quote
Old 09-24-2002, 02:17 AM   #3
oldace84
CF Senior Member
oldace84's Avatar
Default Re: Install of Dyna Mod HEI Module (vettl83)
Thanks for the tip.....did you remove the distruitor, or install with it in the car?????
Let me know..OK????OK!!!
THANKS
TONY :smash:
Old 09-24-2002, 02:35 AM   #4
Hole-Shot
CF Senior Member
Hole-Shot's Avatar
You do not have to remove the distributor. Just pull off the cap and follow the instructions. It is a easy job.
Hole-Shot is offline   Reply With Quote
Old 09-24-2002, 02:38 AM   #5
oldace84
CF Senior Member
oldace84's Avatar
Default Re: Install of Dyna Mod HEI Module (Hole-Shot)
Thanks again...
tony :cheers:
Old 09-24-2002, 08:08 PM   #6
Raistlin
CF Senior Member
Send a message via AIM to Raistlin Send a message via MSN to Raistlin Send a message via Yahoo to Raistlin
i installed an accell module.
be careful with the wire connectors to the distributor, mine were very brittle after years of heat. plastic in that condition breaks very easily.
Raistlin is offline   Reply With Quote
Reload this Page Install of Dyna Mod HEI Module
Tags
dyna, dynamod, good, hei, mod, module
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
