No Comp Mode
Can't get my 99 manual Trans FRC to go into competition mode. Held the button down for awhile at a dead stop with no luck. BCM issue?
Did it used to work? Did you check your tire pressure? (Low pressure will not let it turn on)
Could also be a tire pressure sensor not reporting. You'll figure it out, good luck! |
Do you have the AH option?
The Active Handling System, RPO JL4, debuted on the 1998 Corvette and became standard equipment on the 2001 model. |
Thank guys, I'll check into this further. DIC keypad is out so going to borrow a Tech II and see what's going on.
Got my build sheet out, not equipped with A/H... Thanks for the input though!
Originally Posted by Old Horsepower
(Post 1587097874)
Originally Posted by 8VETTE7
(Post 1587119332)
Good reason for not being able to enter COMP mode............:rofl:
