No Comp Mode
Old 06-10-2014, 02:11 AM
GreggHammer
GreggHammer's Avatar
Default No Comp Mode
Can't get my 99 manual Trans FRC to go into competition mode. Held the button down for awhile at a dead stop with no luck. BCM issue?
Old 06-10-2014, 02:58 AM
Old Horsepower
Old Horsepower's Avatar
Did it used to work? Did you check your tire pressure? (Low pressure will not let it turn on)
Could also be a tire pressure sensor not reporting. You'll figure it out, good luck!
Old 06-10-2014, 08:13 AM
dadaroo
dadaroo's Avatar
Do you have the AH option?
The Active Handling System, RPO JL4, debuted on the 1998 Corvette and became standard equipment on the 2001 model.
Old 06-10-2014, 10:48 AM
GreggHammer
Thank guys, I'll check into this further. DIC keypad is out so going to borrow a Tech II and see what's going on.
Old 06-12-2014, 01:11 AM
GreggHammer
Got my build sheet out, not equipped with A/H... Thanks for the input though!
Old 06-12-2014, 04:28 PM
BigGun
BigGun's Avatar
Tire pressure does not prevent engaging comp mode (at least on my 99). I don't even have sensors installed and comp mode works as it should.
Old 06-13-2014, 01:40 AM
GreggHammer
Originally Posted by 8VETTE7
Good reason for not being able to enter COMP mode............
I know, right!
To No Comp Mode
Quick Reply: No Comp Mode
