496 Stroker Cam recommendation
In process of getting my 496 BB short block cleaned up after a wiped cam, and need to decide on what cam to replace it with.
Build details: Chevy 427 BB, stroked to 496 cu in Eagle forged rotating assy, SRP -3cc pistons Stock Quadrajet and intake 063 closed iron heads with 2.19/1.88" I/E valves Stock exhaust manifolds with 1969 side exhaust 4-speed M21, close ratio, 3.08 rear Need enough vac for power brakes Car is 1969 coupe, frame off resto. Goals are a reliable highpo street machine for an occasional driver. Don't want/need to go over 6k rpm. Previous cam was a custom hydro FT, 240/244 112 LSA. Was good while it lasted ... Vac was low but acceptable. After going thru the grief of a wiped cam, leaning towards a roller hydro. Recommendations? |
Just one- Chris Straub
He seems to be the "go-to" guy for cams. |
Originally Posted by TimAT
(Post 1584951705)
He seems to be the "go-to" guy for cams. Chris will set you up. http://www.straubtechnologies.com/ |
