Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-18-2013, 04:55 PM   #1
Bobs69BB
CF Member
Default 496 Stroker Cam recommendation
In process of getting my 496 BB short block cleaned up after a wiped cam, and need to decide on what cam to replace it with.
Build details:
Chevy 427 BB, stroked to 496 cu in
Eagle forged rotating assy, SRP -3cc pistons
Stock Quadrajet and intake
063 closed iron heads with 2.19/1.88" I/E valves
Stock exhaust manifolds with 1969 side exhaust
4-speed M21, close ratio, 3.08 rear
Need enough vac for power brakes
Car is 1969 coupe, frame off resto. Goals are a reliable highpo street machine for an occasional driver. Don't want/need to go over 6k rpm.
Previous cam was a custom hydro FT, 240/244 112 LSA. Was good while it lasted ... Vac was low but acceptable.
After going thru the grief of a wiped cam, leaning towards a roller hydro. Recommendations?
Bobs69BB is offline   Reply With Quote
Old 09-18-2013, 04:56 PM   #2
TimAT
CF Senior Member
TimAT's Avatar
Just one- Chris Straub
He seems to be the "go-to" guy for cams.
TimAT is offline   Reply With Quote
Old 09-18-2013, 07:34 PM   #3
71454Chevelle
CF Member
71454Chevelle's Avatar
X2
Chris will set you up.
http://www.straubtechnologies.com/
__________________
Darren
1971 Chevelle
496
CFM Ported Stage 5 Brodix Race-Rites 310cc
10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
71454Chevelle is offline   Reply With Quote
Reload this Page 496 Stroker Cam recommendation
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: Z06 Corsa Exhaust, LS3 Intake with rail/injectors, Stock complete LS3 Heads. Mallett Z C6 Parts for Sale/Wanted 5 07-11-2014 01:04 AM
big block 79 drd21968 C3 General 4 11-16-2013 05:57 PM
Clean up after wiped cam Bobs69BB C3 Tech/Performance 11 07-11-2013 12:45 AM
07 LS2 with LS3 Top Half Z06 Dual Mode exhaust Rattle at Idle in gear - Suggestions? dejanat C6 Tech/Performance 0 05-19-2013 04:28 AM
High speed stumble / Qjet tuning questions Bobs69BB C3 Tech/Performance 27 05-15-2013 01:24 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
