Paul and other xperts: correct wheel lock?
I think these will work, yes?
Originally Posted by RicK T
(Post 1584951757)
why do you need wheels lock?
I believe GM will be selling them as an accessory as well.
Dave |
1 Attachment(s)
Originally Posted by troller399
(Post 1584951817)
Originally Posted by talon90
(Post 1584951837)
Because after you have spent any time on the forum, this is a sight that you never want to see in your own driveway.
^^^^^^I have traveled for a living for 35 years...Since 1980, 4 times I have walked out of holiday and Ramada type properties to see a car up on blocks....I've got two hotels to hit to get my car home, these slow them down a bit...not theftproof, just a deterrent for meth heads...
Originally Posted by Glen e
(Post 1584951886)
(Post 1584951999)
In that case, might be a good reason to consider the 20 lock set? Maybe? :)
(Post 1584952014)
that's what that kit is....and I have another 4 lock kit to mix up the key....
(Post 1584952083)
Hmm, I read it as 16 lug nuts and 4 locks. Maybe I misread.
(Post 1584951673)
Gorilla Automotive 71733 Acorn Chrome Lug Nut and Lock System (12mm x 1.50 Thread Size) : Amazon.com : Automotive I think 71633 and 71733 are the same except 71633 lists only 13/16" wrench size and not 19mm. Rat |
Any acorn/conical wheel lock in a 12x1.5 will work just fine.
Gorilla does sell a kit that will replace all the lugnuts with locks. I will say, that we remove these every day for people that have lost or broken the wheel lock key. If a thief has enough time, they'll still be able to get your wheels. But locks will certainly slow them down. |
I might add that most of the holiday Inn express and other main chains will find you a spot that is illuminated or always watched if you ask. I was part of event staff that toured a BMW X6 and the M5 6 months before they were available. We always would ask and got to park underneath the entrance awning/portal with no problem 95% of the time...just ask...
Do they make black ones for those of us that ordered black wheels/ I would think it would look very tacky to have black wheels/rims and 5 bright nuts..
:lol: (bright nuts) |
Originally Posted by yellowsnow
(Post 1584952540)
(Post 1584952540)
2LT and 3LT have tilt sensors. Alarm will go off if the car tilted to steal the wheels, or tow. However, buy the wheel locks. I have the Gorilla Automotive wheel locks on all my cars, including the C6.
I looked on Amazon at part # 71633NBC and at part #21133BC, but their size calculator says that it will not fit my car... 2014 or 2013 Chevy Corvette
