Paul and other xperts: correct wheel lock?
Old 09-18-2013, 04:52 PM
Glen e
Glen e's Avatar
Default Paul and other xperts: correct wheel lock?
I think these will work, yes?
Gorilla Automotive 71733 Acorn Chrome Lug Nut and Lock System (12mm x 1.50 Thread Size) : Amazon.com : Automotive Gorilla Automotive 71733 Acorn Chrome Lug Nut and Lock System (12mm x 1.50 Thread Size) : Amazon.com : Automotive
Old 09-18-2013, 05:03 PM
RicK T
RicK T's Avatar
Yes.
Just some info if you want to read:
http://forums.corvetteforum.com/c6-c...-question.html
Old 09-18-2013, 05:08 PM
Glen e
Glen e's Avatar
Originally Posted by RicK T
Yes.
thanks - was pretty sure that the c7 was the same....
Old 09-18-2013, 05:10 PM
ATC399
Support Corvetteforum!
ATC399's Avatar
why do you need wheels lock?
Old 09-18-2013, 05:13 PM
Dave@Ciocca
Platinum Supporting Dealership
Dave@Ciocca's Avatar
Received 1,656 Likes on 393 Posts
I believe GM will be selling them as an accessory as well.
Dave
Old 09-18-2013, 05:14 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Because after you have spent any time on the forum, this is a sight that you never want to see in your own driveway.
Old 09-18-2013, 05:18 PM
MThomas
MThomas's Avatar
I spent 32 years in law enforcement and just retired last November. HELL YES put locks on your wheels.
Old 09-18-2013, 05:20 PM
Glen e
Glen e's Avatar
^^^^^^I have traveled for a living for 35 years...Since 1980, 4 times I have walked out of holiday and Ramada type properties to see a car up on blocks....I've got two hotels to hit to get my car home, these slow them down a bit...not theftproof, just a deterrent for meth heads...
Old 09-18-2013, 05:32 PM
RicK T
RicK T's Avatar
In that case, might be a good reason to consider the 20 lock set? Maybe?
Old 09-18-2013, 05:34 PM
Glen e
Glen e's Avatar
that's what that kit is....and I have another 4 lock kit to mix up the key....
Old 09-18-2013, 05:41 PM
RicK T
RicK T's Avatar
Hmm, I read it as 16 lug nuts and 4 locks. Maybe I misread.
Old 09-18-2013, 05:44 PM
Glen e
Glen e's Avatar
gotcha - you are correct...I'll have two keys on each wheel
Old 09-18-2013, 06:11 PM
CaptRat
CaptRat's Avatar
Something is a bit strange with the product in that Amazon link. It says it's Gorilla 71733, the package in the photo says 71783. 71783 is 1/2 x 20 vs 12 x 1.5. Which is it they're selling?
I think 71633 and 71733 are the same except 71633 lists only 13/16" wrench size and not 19mm.
Rat
Old 09-18-2013, 06:17 PM
WELEPRO
WELEPRO's Avatar
Any acorn/conical wheel lock in a 12x1.5 will work just fine.
Gorilla does sell a kit that will replace all the lugnuts with locks. I will say, that we remove these every day for people that have lost or broken the wheel lock key. If a thief has enough time, they'll still be able to get your wheels. But locks will certainly slow them down.
Old 09-18-2013, 06:22 PM
Glen e
Glen e's Avatar
I might add that most of the holiday Inn express and other main chains will find you a spot that is illuminated or always watched if you ask. I was part of event staff that toured a BMW X6 and the M5 6 months before they were available. We always would ask and got to park underneath the entrance awning/portal with no problem 95% of the time...just ask...
Old 09-18-2013, 06:39 PM
yellowsnow
yellowsnow's Avatar
Do they make black ones for those of us that ordered black wheels/ I would think it would look very tacky to have black wheels/rims and 5 bright nuts..
(bright nuts)
Old 09-18-2013, 06:50 PM
Glen e
Glen e's Avatar
(bright nuts)
of course they do...make amazon your friend....
To Paul and other xperts: correct wheel lock?
Old 09-18-2013, 06:53 PM
Matt26
Matt26's Avatar
(bright nuts)
Yup, part number 71633nbc
Amazon.com: Gorilla Automotive 71633NBC "The System" Acorn Black Chrome Wheel Locks (12mm x 1.50" Thread Size) - For 5 Lug Wheels: Automotive Amazon.com: Gorilla Automotive 71633NBC "The System" Acorn Black Chrome Wheel Locks (12mm x 1.50" Thread Size) - For 5 Lug Wheels: Automotive
Old 09-18-2013, 07:11 PM
bimmerborn
bimmerborn's Avatar
2LT and 3LT have tilt sensors. Alarm will go off if the car tilted to steal the wheels, or tow. However, buy the wheel locks. I have the Gorilla Automotive wheel locks on all my cars, including the C6.
yellowsnow
yellowsnow's Avatar
I looked on Amazon at part # 71633NBC and at part #21133BC, but their size calculator says that it will not fit my car... 2014 or 2013 Chevy Corvette
Quick Reply: Paul and other xperts: correct wheel lock?
