-   C3 Tech/Performance (https://www.corvetteforum.com/forums/c3-tech-performance-3/)
-   -   4-hole carb spacer (https://www.corvetteforum.com/forums/c3-tech-performance/3308928-4-hole-carb-spacer.html)
gkull 07-22-2013 10:23 AM
Originally Posted by augiedoggy (Post 1584462831)
Its funny edelbrock carbs take a lot of heat here (not literally) but I noticed this past Wednesday at a large carshow that the majority of the cars had edebrock carbs on them... Yes their were holleys and even quads on the stickers but by far the most common Carb was the carter/Weber/edelbrock series that everyone hates so much...
I did some research as to why people in upstate New York use Edl carbs. Evironmentalists haven't determined the exact cause of the higher rate of mental illness per 100,000 people in that region:D
IMO - the mental issue........ ya, to some extent .............. I just think that it is economics. These modded double pumpers are $1000 bucks.
694speed350 07-22-2013 05:22 PM
Originally Posted by Scottd (Post 1584466420)
Simply because they are the most abundant aftermarket carb and they are very easy to maintain, tune and install. Ive run several Edelbrocks in the past (for the above reason) but they do have their weak points.
Have to disagree Holley is the easiest to maintain:flaghalfmast::leaving:.
scottyp99 07-23-2013 01:54 AM
Originally Posted by gkull (Post 1584469758)
scott which carb do you have? 9/16ths is .563 inches
CARB VENTURI BUTTERFLY
Holley 750/750HP 1.375" 1.6875"
Holley 830 1.562" 1.6875"
Holley 850/850HP 1.562" 1.750"
Holley 950HP 1.375" 1.750"
Holley Ultra 950HP 1.600" 1.750"
Holley 1000HP 1.562" 1.750"
QFT/Proform 750 1.375" 1.6875"
QFT/Proform 850 1.400" 1.750"
QFT 950 1.450" 1.750"
Demon 750 1.401" 1.6875"
Demon 800 NEW 1.425" 1.750"
Demon 825 OLD 1.425" 1.750"
Demon 850 1.562" 1.750"
Demon 950 1.590" 1.750"
It's one and nine sixteenths inches. Maybe the way I wrote it was confusing, I don't know the convention for writing it in print, so I just wrote 1 9/16". It's an old, plain-Jane, garden variety Holley 1850 600 vacuum secondary carb. It has 1 9/16" throttle bores. I just measured a spare that I have lying around, with my trusty old micrometer. 1.556", close enough to 1 9/16" for government work. I can't be the only guy in the world who's fussy about stuff like this, can I?
Scott
gkull 07-23-2013 02:49 AM
600 CFM Vacuum Secondary. Tiny 4 hole spacers are not common because you don't see 450 - 600 cfm double pumpers very often.
VS carbs are not subject to lack of booster signal do to low vacuum when all 4 throttle bores open like on a double pumper.
4 holes are to help on tall plenum single planes and would probably be detrimental in a small plenum dual plane if that is what you have.
scottyp99 07-23-2013 08:42 PM
Yes, it's on an Edelbrock Performer 2101 Intake. Thanks for the insight, gkull, I'll take it under advisement.
Scott
scottyp99 07-27-2013 11:26 AM
Looks like summit Racing came through for me:
http://www.summitracing.com/parts/hly-17-59
It's mainly for insulation, in my case, but I don't think I want to use an open spacer. I would like to keep the two sides of the dual-plane intake separate. I think this spacer is what I want, even though I think it's a little pricey. Right now, with the 1" thick spacer I have on the engine, I have about 1/16" of an inch of hood clearance, this will free up an additional 1/2", which will make me more comfortable, too. Thanks for all the input, guys.
Scott
