Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-21-2013, 02:24 AM   #1
scottyp99
CF Senior Member
scottyp99's Avatar
Default 4-hole carb spacer
This isn't Corvette specific, but it's for my 'vette, and there's a buncha smart, helpful people on this forum, so I figured I'd give it a shot here. Can anybody tell me where I can purchase a 4-hole, phenolic, 1 inch thick carb spacer for a Holley 1850 with 1 9/16" holes? Can't seem to find one anywhere. Do they exist? Or are they all made larger so as to be a more universal fit? Thanks in advance for any help,
Scott
scottyp99 is offline   Reply With Quote
Old 07-21-2013, 05:44 AM   #2
MelWff
CF Senior Member
MelWff's Avatar
have you tired www.summitracing.com or www.jegs.com
MelWff is offline   Reply With Quote
Old 07-21-2013, 09:30 AM   #3
vetteguy75
CF Senior Member
LA Events Coordinator
Support Corvetteforum!
vetteguy75's Avatar
Quote:
Originally Posted by MelWff View Post
vetteguy75 is offline   Reply With Quote
Old 07-21-2013, 09:40 AM   #4
gkull
CF Senior Member
gkull's Avatar
wood is the best thermal barrier
http://www.jegs.com/i/JEGS-Performan...ductId=1615166
gkull is online now   Reply With Quote
Old 07-21-2013, 10:57 AM   #5
Scottd
CF Senior Member
http://www.summitracing.com/search?k...20spacer&dds=1
Here ya go. 7 pages of phenolic spacers. These are essential if you are running a heat sink prone Edelbrock.
Scottd is offline   Reply With Quote
Old 07-21-2013, 11:48 AM   #6
augiedoggy
CF Senior Member
Its funny edelbrock carbs take a lot of heat here (not literally) but I noticed this past Wednesday at a large carshow that the majority of the cars had edebrock carbs on them... Yes their were holleys and even quads on the stickers but by far the most common Carb was the carter/Weber/edelbrock series that everyone hates so much...
augiedoggy is offline   Reply With Quote
Old 07-21-2013, 11:59 AM   #7
bluedawg
CF Senior Member
bluedawg's Avatar
Quote:
I wonder if this is because you can get a carb writhe the top end combos that edelbrock sells?
bluedawg is offline   Reply With Quote
Old 07-21-2013, 03:53 PM   #8
alswagg
CF Senior Member
I have made several wood carb spacers. Usually out of Walnut. The wood is very dense and does not absorbe fuel easily.
alswagg is offline   Reply With Quote
Old 07-21-2013, 04:43 PM   #9
7t9l82
CF Senior Member
7t9l82's Avatar
its edelbrocks marketing and price. some people are happy that the car even runs.
7t9l82 is offline   Reply With Quote
Old 07-21-2013, 08:10 PM   #10
Scottd
CF Senior Member
Simply because they are the most abundant aftermarket carb and they are very easy to maintain, tune and install. Ive run several Edelbrocks in the past (for the above reason) but they do have their weak points.
Old 07-21-2013, 08:12 PM   #11
scottyp99
CF Senior Member
scottyp99's Avatar
Do any of them have 1 9/16" bores?
OK, maybe I'm being a little obtuse here. My point is that none of them say what diameter the holes are. I've finally broken down and sent Summit a message asking them if they have any 4-hole, phenolic spacers with 1 9/16" holes. Waiting to hear back from them.
Scott
Old 07-21-2013, 08:32 PM   #12
gkull
CF Senior Member
gkull's Avatar
Wood is what you want, But the idea from a 4 hole is better signal to the boosters. So they are sold as 4150 size......
Circle track racers us 1/2 inch.. The A/F is heading straight down and at some point has to take a nearly 90 degree angle to the intake valve. Tall single planes only use a 1/2 inch wood spacer.
As to matching the throttle blades size. is a mute point
Old 07-21-2013, 09:21 PM   #13
jnealg
CF Senior Member
jnealg's Avatar
Quote:
Originally Posted by 7t9l82 View Post
its edelbrocks marketing ..
Same reason people buy Monster cables and Bose sound systems.
Mediocre at best but there are ALWAYS those that will defend them.
Marketing genius.
__________________
J. Neal Goggins
1975 l48 Silver Convertible
1996 Lt1 Black coupe (so long and thanks for all the fish!)
http://www.carcaptures.com
Quote:
Originally Posted by oldschoolvette View Post
I just spent two weeks chasing that flaming F-monkey around my garage)
jnealg is offline   Reply With Quote
Old 07-21-2013, 09:36 PM   #14
scottyp99
CF Senior Member
scottyp99's Avatar
Really? I figured it was important to match the spacer hole diameter with the throttle bore diameter. And, wouldn't a wood spacer eventually rot out from the gasoline? Especially if it was made of plywood?
I don't understand what you mean by "sold as 4150 size". 4150 style carbs come with several different throttle bore sizes.
Scott
Old 07-21-2013, 09:45 PM   #15
Mod75
CF Senior Member
Mod75's Avatar
I am all ears, i had a 4 hole spacer ( don't know what size ).
Am now using an open chamber one on my Edelbrock and holly 1850 to reduce the heat to the carb.
Is this good/bad idea? Guess i should check out my bore spec also.
Mod75 is offline   Reply With Quote
Old 07-22-2013, 12:52 AM   #16
shok
CF Senior Member
Does the carter AFB that the Edelbrock is modeled after share the same negative feelings around here?
shok is offline   Reply With Quote
Old 07-22-2013, 03:09 AM   #17
rcread
CF Senior Member
rcread's Avatar
My company makes Woodfiber laminate spacers for Edelbrock. They are a composite of wood and plastic. We make a 1" thick, 4-hole spacer. These are made in the USA (Seattle, right below my office). When I get to work tomorrow, I will double check the diameter, but they should match the diameter of the Holly carb.
rcread is offline   Reply With Quote
Old 07-22-2013, 07:37 AM   #18
LudemJo
CF Senior Member
LudemJo's Avatar
I actually just installed a 4-hole spacer on a Edelbrock 1406 carb on a Edelbrock 2101 manifold, trying to combat a vapor lock/fuel percolation problem on my 74. The car ran so badly with the spacer that I immediately took it back off. I assume there are carb adjustments that have to be made when these spacers are installed. I don't know enough about adjusting carbs at this time to make those adjustments, so I took it back off. It will be nice when the cooler weather comes back so I can not have to worry about this problem, and getting stranded as a result.
My spacer was wood, purchased from Jegs. I fully believe that this is the right solution to the problem just need to be aware that it may require other adjustments...not always just plug and play.
John
LudemJo is offline   Reply With Quote
Old 07-22-2013, 09:13 AM   #19
augiedoggy
CF Senior Member
Marketing genius.
true, I wasn't necessarily defending them myself but My car came with one and since they are easier to maintain and setup they do have some advantages there.....
One could say the Holley is so popular for the same reasons.... ask anyone who knows very little about engines and they think the "Holley double pumper "is the ultimate bolt on mod of course the 750 is used regardless if its way too big for the engine or not..
Anyway back on topic....
I was given a couple 4 hole spacers but they are 2" and plastic
Old 07-22-2013, 09:29 AM   #20
gkull
CF Senior Member
gkull's Avatar
scott which carb do you have? 9/16ths is .563 inches
CARB VENTURI BUTTERFLY
Holley 750/750HP 1.375" 1.6875"
Holley 830 1.562" 1.6875"
Holley 850/850HP 1.562" 1.750"
Holley 950HP 1.375" 1.750"
Holley Ultra 950HP 1.600" 1.750"
Holley 1000HP 1.562" 1.750"
QFT/Proform 750 1.375" 1.6875"
QFT/Proform 850 1.400" 1.750"
QFT 950 1.450" 1.750"
Demon 750 1.401" 1.6875"
Demon 800 NEW 1.425" 1.750"
Demon 825 OLD 1.425" 1.750"
Demon 850 1.562" 1.750"
Demon 950 1.590" 1.750"
Reload this Page 4-hole carb spacer
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
