(Post 1584368243)
I am afraid to ask to see pictures of the documents you received I would be curious if you could find the original color of the car by removing the kick panels and looking around for original over spray
I would remove both.
:iagree:
That VIN 194377S102817 does not show up on usual search tries and car 2817 is not listed at C2 registry. There are many hints that could be checked to see if it was really a big block car, or an AO Smith car, or a black car, or a TI car etc etc but with those TRIM, VIN and PAD findings not sure it matters :eek::eek: |
Originally Posted by JUST TRY 03
(Post 1584367948)
this is getting intresting, what specifically would you like pictures of?
so is it safe to say that i have a "fake" big block 67?
(Post 1584368410)
1. Fake trim tag 2. re-stamped block With more info., the more we will know.:cheers: Jim |
(Post 1584368410)
(Post 1584368452)
Well for all we know your car could have been a born with BB car. But now your big concern is why was the vin tag removed and why the bogus trim tag. And is that the original vin tag for that body and if it matches the vin on the frame.
Yes you can. Its on the driver s side on the top of the frame in the wheel house area. You will need a good light a mirror and a good eye. Some stamps were light and some were deeper. It also depend how much and what type of paint was used on the frame. Good luck
VIN more specifically on a 66-67 usually above the front edge of the #4 body mount bracket. Remove the rear wheel to see in there better and a really good light helps :cheers:
(Post 1584368258)
ill remove the kick panels in the morning, is it just the passenger or driver's side panel?
Did you mention in prior posts whether this is a side pipe car? |
Originally Posted by A-Snake
(Post 1584369559)
You may also be able to look under the carpet behind the removable interior 1/4 panels. Open the rear deck and pull back the carpet where it reaches the top of the fenders.
Originally Posted by 65GGvert
(Post 1584370022)
Exactly what do you mean by "open the rear deck"? This is a 67 coupe. Are you talking the jack area cover?
(Post 1584370911)
That's means I spaced out and forgot it was a coupe. :crazy2: Sorry about that :thumbs:
alright i removed the kick panels, i did not see any other color or primer color, it was all black. And yes this is a side pipe car. I tried to look for the vin on the frame, no luck. i can barely get my fingers between the body/frame let alone a mirror or anything else.
Did you see if it was an original sidepipe car? Are the factory cuts there?
(Post 1584371259)
