Trim and Vin tag decoding help
Ive searched and and am still confused on the options for this car, is there anyway to tell if its a numbers matching engine? and what it was built with orginally? thanks for your help
Vin is 1943775102817
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Received 6,944 Likes
2015 C2 of Year Finalist
you have a 67 coupe with a body build date of November 1, 1966 at St. louis plant. with Black leather seats and all black interior, and black exterior. the cars birthday is November, 2 1966. to me those two dates are too close together. and the trim tag looks like it has been removed from a car. you can see where the drill bit skipped by the rivet. and the rivets on the vin tag are 100% wrong. so that has been removed too. can you tells us more about the car
Received 1,857 Likes
The trim tag says it's a St. Louis-bodied coupe with black paint and black leather seats, body built on November 1st, car produced about November 2nd. However, the trim tag looks like it was made yesterday.
The VIN plate has been off the car, and has been re-installed with the wrong rivets.
As Nowhere Man has pointed out, both tags are problematic, both have fresh rivets and for a 1967 VIN tag to not have correct rosette rivets is a huge problem. All those rivets look fresh and that Trim Tag does not appear to be 40+ years old. Any chance you can check the frame VIN number (driver's side rear on top of frame)?
1 Post
so John St. Louis bodies build date can be made the day before the cars vin b-day?
The trim tag is a repo. Compared side by side to an original, the differences are glaring. Must be a coincidence that it's also for the rarest color in 67.
Here's one of several items wrong with the trim tag. Compare the "Y"s.
Real -
The OP's tag -
Enough said.
Jim
Real -
The OP's tag -
Enough said.
Jim
I agree with others here, that the trim tag on the OP's car, looks too new. It sure looks like a repro tag to me. I might not be as quick to question it, if it we were talking about a Daytona Blue 64, but when it's a black 67, that just makes me all the more suspicious.
I was at one of those seminars about 4 years ago so all the fine details left me. I am with about the fake tag.
That's only the casting number. In the front of the block there is a machined surface. Post that
I agree you need to continue to look unless you do not care about buying a real original midyear. I looked for quite a while and finally found my 67 427 - it is a color change, but I do not care as the car is the real deal and known history with the original engine/trans/rear and most other correct parts. If I ever want to have it judged (am not into that), I can repaint, otherwise, I have the best of both worlds, a real 67 427 convertible and currently its red!
Ron
Ron
Ron
Ron
The caliber of guys on this forum is triple AAA rating. I am stunned by and happy how quick BS can be spotted. I have always wanted to trade up my 67 l-79 vert with POP and tank sticker (owned 20 years) with a 67 427 and always balked. I may be glad I did as if I traded my pride and joy for a fake BB, I would jump off a bridge. Thank you all for the dedication to this laborious hobby.
I think the most popular color in 67 was Goodwood Green, the color my car should be, and Black was the rarest. I rarely see any green 67s today. Resale Red.
Absolutely! It took about two shifts for a unit to go through the entire system, from the beginning of the Body Shop to the shipping gate. If it started on a Friday, it might not make it until Monday, but if it started first thing in the morning in the Body Shop (7:00 AM), it could reach the shipping gate by the last hour of second shift on that same day.
