OP Update: Bad news
The bad news:
Cruising the highway speeds shoots the temps up. It never breeched 240 (probably cause it was a cool 75 deg out that day), but came damn close. I'm thinking that the radiator just cant keep up with the high rpms. Note: Highway speeds = A sustained speed at or around 70 mph with an rpm of about 3750 |
Originally Posted by tebok
(Post 1584658748)
The good news:
The DeWitt's radiator is installed and is working like a dream. It can idol and cruise around the city all day. The initial test was in the garage where at idol it raised up to 195, the fans kicked on, and it dropped back down to 175. I let it go through two cycles of raising up and falling down to my delight. [I just read your "bad news" message :( ] -- Steve |
(Post 1584658773)
The bad news:
(Post 1584658773)
The bad news:
Cruising the highway speeds shoots the temps up. It never breeched 240 (probably cause it was a cool 75 deg out that day), but came damn close. I'm thinking that the radiator just cant keep up with the high rpms. Note: Highway speeds = A sustained speed at or around 70 mph with an rpm of about 3750 have you changed the water pump?.....sorry you are going through this |
Originally Posted by midyearvette
(Post 1584658979)
run a block check with liquid that changes color to see if you have a combustion leak.....jmo.....:cheers:
have you changed the water pump?.....sorry you are going through this Both these checks have been done. |
(Post 1584658773)
The bad news:
Cruising the highway speeds shoots the temps up. It never breeched 240 (probably cause it was a cool 75 deg out that day), but came damn close. I'm thinking that the radiator just cant keep up with the high rpms. Note: Highway speeds = A sustained speed at or around 70 mph with an rpm of about 3750 Dennis:cheers: |
(Post 1584659208)
Thanks for your input, but please read the thread through before posting.
Both these checks have been done. i will tune in at times to see if you solve it....:rock: |
(Post 1584658773)
The bad news:
Cruising the highway speeds shoots the temps up. It never breeched 240 (probably cause it was a cool 75 deg out that day), but came damn close. I'm thinking that the radiator just cant keep up with the high rpms. Note: Highway speeds = A sustained speed at or around 70 mph with an rpm of about 3750 It is quite likely you had multiple causes feeding into your initial overheating condition. I did too. For me, it was a combination of the wrong radiator, poorly functioning aftermarket carb, clogged cooling system, and airflow issues (including airflow through the entire radiator impeded by a previously-installed dual fan kit, which was replaced with a proper fan and oem fan shroud) - all were contributing to my situtation. In my case, the first thing I did when tackling this issue was replace the radiator with the exact replica unit from Dewitt, which helped, but did not cure, my overheating situation. So I feel for you - been there. You have certainly addressed the radiator piece, and now can focus on other contributors. With all that said, you must be extremely frustrated. I certainly was, when I was in your shoes. |
(Post 1584658773)
The bad news:
Cruising the highway speeds shoots the temps up. It never breeched 240 (probably cause it was a cool 75 deg out that day), but came damn close. I'm thinking that the radiator just cant keep up with the high rpms. Note: Highway speeds = A sustained speed at or around 70 mph with an rpm of about 3750 Have you checked if the fans are blowing or sucking air? If your fans are turning in the wrong direction they will help cooling the radiator in your garage, but when they are on at highway speed they are blocking the airstream through radiator. |
Originally Posted by Dennis Beck
(Post 1584659304)
I've been following along. Just a FYI. I have a zz383 with a Dewitt radiator and 3:55 rear end. 180* thermostat. Stock fan and fan clutch. Mine runs 180* ALWAYS. Stop light to stop light, 90*+ air temp, 75mph for 200 miles on the highway etc. I know this doesn't solve your issue but you should expect better results.
Dennis:cheers: I'm coming to the conclusion that this isn't a simple cooling issue and that it's internal. The car runs well enough now that I can enjoy it and that's most likely where it will stay until I have the time and money to deal with the motor internals. |
Originally Posted by 1965fuelie
(Post 1584659519)
(Post 1584659519)
Well, the equal of that DeWitts radiator for my '61 car keep my 427 SB cool, though temps do creep up under full throttle passes down the 1/4 mile.
You have verified that there is no head gasket leak, you have a new rad and water pump. I would try one last little thing, even though your Tstat is new, it could be bad. I had a new Tstat fail, causing my car to overheat at highway speeds. Take it out, put it in a pot of boiling water and make sure it is fully open. Perhaps that .060" overbore, is simply too much, on your motor. Are you sure it is only .060" over, and someone didn't get creative trying to get more cubes out of it? Too thin of a cyl wall will give you high speed overheating. Doug |
Originally Posted by AZDoug
(Post 1584660688)
(Post 1584660794)
I'm afraid you most likely are correct. The info I posted here is all that I have on the rebuild. I will certainly keep the numbers matching motor with the car, but maybe I'll swap it with another down the road some day when I have more cash. Time will tell
If you just want to drive it, find a 327 or 350 and drop it in while you contemplate what to do with the original block. Doug |
(Post 1584660794)
I could agree that thin cylinder walls will bleed more heat into the cooling system but doubt it would cause your remaining problem. |
Originally Posted by MikeM
(Post 1584662100)
At the first of this thread, it was suggested you double check your new thermostat. I don't recall you ever confirming you did. But maybe you did.
I could agree that thin cylinder walls will bleed more heat into the cooling system but doubt it would cause your remaining problem. Also wonder about the lower radiator hose possibly collapsing at high water pump speed. If replaced already maybe got a soft one, worth a try (although I loath replacing my lower rad hose, a real PITA). If trying that, use something like Paragon pn 1733 (correct hose, looks el correcto, and includes the spring inside to keep it from collapsing.) |
Well I will just add my .02 here just because, I have been following this thread from day one and I'm up to date on everything you have done or tried.
So after all that if it was me this motor would now be setting on my engine stand. First thing I would do is remove the freeze plugs and have a look see inside the block for any blockage or heavy scale buildup. Next on my list would be a complete teardown and rebuild to stock specs. A 327/365hp motor is not something special and should run 180 degrees all day long. I had a 66 with a plain Jane 350 hooked up to a 30 year old stock radiator and this car never ran over 180 period. Now the above might sound extreme but I’m a extreme kind of guy when something like this gets under my skin. I’m in the baby steps of dialing in my 427 on a run stand and I too am having temp problems right out of the gate so I feel your pain. But that is another thread for another day. Hang tough, you will win this. Dennis |
If I recall where you have been already, Timing is good, Radiator is perfect now, water pump is replaced, Thermostat has been checked/replaced, no air in the system.
Engine passed the sniff test so no combustion in radiator. You are running out of things that could cause this. Now the remaining problem is high temp at freeway speeds only? Thousands of 327's ran at .060 over with no heating issues, even in work trucks so I don't lean toward that. Was the block flushed? I know there was lots of talk about it, did it flush and what came out? Exhaust excessive back pressure can cause heat issues. Hard to test but worth a check. Normally if you have this kind of back pressure issue you would also notice the engine power falling off. With 4.11's spinning 3,750 you might not notice a 10-15% drop in power. Did you pull the plate off the back of the water pump to inspect the impeller. The low price units are not positive displacement and it may cavitate at the high RPM's. |
Originally Posted by Mr D.
(Post 1584662575)
