eLSD came from where!
http://en.wikipedia.org/wiki/Limited_Slip_Differential
An electronic limited-slip differential will typically have a planetary or bevel gear set similar to that of an open differential and a clutch pack similar to that in a torque sensitive or gerotor pump based differential. In the electronic unit the clamping force on the clutch is controlled externally by a computer or other controller. This allows the control of the differential’s limiting torque, Trq d , to be controlled as part of a total chassis management system. An example of this type of differential is Subaru’s DCCD used in the 2011 Subaru WRX STi.[7] Another example is the Porsche PSD system used on the Porsche 928. A third example is the SAAB XWD (Haldex Generation 4) with eLSD, it uses a common (electronically controlled via the vehicle computer network) hydraulic power pack to control both the longitudinal and transversal torque transfer of the XWD system. The same Haldex system is used on several other GM Epsilon based vehicles such as the Cadillac SRX etc. :confused2:(It's twenty years old, but, far more advantages in a Vette!):rock: |
GM had to add it!
Nvm
Me!?
Originally Posted by Kappa
(Post 1584195829)
Nvm
Anyway, a great way to keep the power coming more, and not pulling timing.:thumbs: :rock: |
all applications to date have been disasters for performance.... we'll see. I have not driven the 2013+ porsches.
from information provided in the c7 presentations, the ediff will not work quickly enough to be anything but a nanny, rather than a performance enhancement. |
Seems to be incorporated pretty well!
Originally Posted by ramey
(Post 1584197442)
from information provided in the c7 presentations, the ediff will not work quickly enough to be anything but a nanny, rather than a performance enhancement. The eLSD is fully integrated with StabiliTrak and Performance Traction Management systems. Its calibrations vary among three modes, based on the Drive Mode Selector setting: •Mode 1 is the default setting for normal driving and emphasizes vehicle stability •Mode 2 is engaged when electronic stability control is turned off in the Sport or Track Driver Modes. This calibration enables more nimble turn-in and traction while accelerating out of a corner •Mode 3 is automatically selected when Performance Traction Management is engaged. This calibration has the same function as Mode 2, but is fine-tuned to work with Performance Traction Management. It makes sense to me that this stuff may have had a hand in the 3.8s 0-60? I sure can't see any other way! And that is .1s!:D :rock: |
