:cool::cool::cool:
Too cool my brother! |
Why not a rolling burn out, you don't take a risk on over heating the brakes.
http://youtu.be/-LGCkhK0lAI Riggs |
Destroyed the u-joint right next to the battery box last year........ the holes still there..............:rofl:
I haven't tried it my vette, kinda afraid of the rear end (makes noise already). But in my 'little' truck - put it in 3rd gear, push the brake on hard, push the line-lock button on top of the verti-gate shifter, let off the brakes, rev to about 4000 and slip foot off the clutch pedal, try to feather the throttle just above the rev-limiter (about 6800) and let off the line-lock button when I can't see out the windshield anymore, steer to keep it straight until it just start to grab then let off...
Originally Posted by vetteguy75
(Post 1583055485)
whenever I stomp on my accelerator from a stand-still, I just get pure acceleration...no squeal or tire burning...just GO!
Originally Posted by PaPaPork
(Post 1583082095)
I had the same problem, two cap nuts and a bit of gas line teflon tape solved it! (and the inner bubba woke up in me!):cheers:
Originally Posted by 63mako
(Post 1583058105)
Wow! Some of you guys never lived, really!:willy:
Manual- Put the vehicle in 1st, Lift off clutch just enough to take all the play out of the drivetrain. Push R foot to floor as you lift left foot off floor. Automatic- Put car in Drive. From a dead stop stomp accelerator to floor. My Bone Stock 1972 L48 400 turbo W/ 3.08 gears would roast the tires using the automatic method above. If your car will not roast the tires using these methods it is time to do some work to it, tuning, timing curve, ignition components, carb tuning or new performance parts.. Reving to 4000 RPM and dumping the clutch or dropping it into gear, Neutral drops or "backoffs" (reverse drops) will tear drivetrain components out and can cause severe damage. Wheel hop is another problem and will require some trial and error rear suspension work to eliminate. nothing says "you're too old" when you can't chuckle at all of those above techniques. Yeah, it tears it up - I wouldn't be a hotrodder if I didn't break stuff doing really silly things. Yep, eventually something will break - so what? they'll rebuild it with better parts.... and eventually stop breaking stuff AND be the next gen of hotrodders rather than car-appliance buyers. When my GTO was in the shop for warranty work, the dealership "blessed" me with a Volt. I absolutely hated that car - there was nothing about it to be excited about - and worst of all, even with all the tried and true methods for doing a burnout.... nada. That is the future of cars - all because some flipping old guy had his fun and wants to keep others from having theirs. :leaving: seriously, embrace your inner youth..... :rock: |
Put it in high gear and move into the bleach or water box and press on the gas....if you cant spin the tires this way, go home.... your cluttering the track up.....and embarrassing yourself.....This happens at the Woodward Dream cruise quite often......:rofl:
(Post 1583100954)
What does all this mean?:D
two cap nuts with the same thread size as the break lines going into calipers, remove the nuts connecting the line to caliper, wrap it in gas teflon tape, screw the cap nut on that, the cap nut "cap" should fit into the caliper hole where the break line used to go, it should not dangle. After doughnuts and burnouts the line stayed in place on my car I wanted to check how much difference it is to do a burnout with line lock before I buy and mount one, so I did. BUT I WAS BEING AN IDIOT - PLEASE DONT BE ONE:cheers: |
Originally Posted by SuperBuickGuy
(Post 1583102062)
really?
nothing says "you're too old" when you can't chuckle at all of those above techniques. Yeah, it tears it up - I wouldn't be a hotrodder if I didn't break stuff doing really silly things. Yep, eventually something will break - so what? they'll rebuild it with better parts.... and eventually stop breaking stuff AND be the next gen of hotrodders rather than car-appliance buyers. When my GTO was in the shop for warranty work, the dealership "blessed" me with a Volt. I absolutely hated that car - there was nothing about it to be excited about - and worst of all, even with all the tried and true methods for doing a burnout.... nada. That is the future of cars - all because some flipping old guy had his fun and wants to keep others from having theirs. :leaving: seriously, embrace your inner youth..... :rock: This "old guy" has 527 hp + a little red button that bumps it up 150 HP, a close ratio 6 speed and a 12 bolt 4.11. I can do a burnout with 295-50-15's going 55 down the highway in 4th gear just stomping the accelerator. That is all the embracing of my inner youth I need.:D |
This is the most childish, immature thing ive seen people do.First to do it proper ,you have to have some hp,if you dont have hp,please,dont humiliate yourself by doing a power brake burn out:crazy2: Its a proper burnout when all you have to do is just mash the gas peddle without touching the brakes :thumbs: But whether its done proper or not ,its a big waste of good money . And it does look silly doing it on the street.
In my youth I decided to find the outer limits of my engine/trans of my 73 Camaro. After consuming more than a few beers, yes reckless youth that i was, I took it down the street to the school parking lot late 1 night. It took quite awhile actually to find the breaking point of the driveline. Many neutral drops and reverse to 1st burnouts later, I broke a u joint, busted the trans case, and gashed a hole in the drive shaft tunnel. We pushed it home, wasn't far, had a trail of trans fluid following us home. and that began my 1st street car build up. By the time it was done, it sported a well built 350, b&m turbo 400, and a 12 bolt posi. I had it on the bottle for several yrs too. Fun stuff.
Some 35+ yrs later I still get a kick out of toasting the tires now and then in my 92 corvette. Just punch it, from anything below 25 mph and it toasts the 295/35/18 rear tires. And I did not put thousands of dollars into my 72 vettes engine build for gas mileage either. |
(Post 1583055485)
I'm not planning to do a burn-out
(Post 1583104917)
The guy asked "how to do a burnout?" Not "how to drop a transmission"
Originally Posted by Billysvette
(Post 1583105376)
http://i31.photobucket.com/albums/c3...8_img010-1.jpg
Anybody who thinks this isn't fun just hasn't tried it. |
(Post 1583123742)
how many lawn chairs can fit in the back of your Corvette? :D
Originally Posted by BKbroiler
(Post 1583124783)
(Post 1583127525)
Thats different ,your at the track racing, yes thats fun,but just sitting in a street and power braking just to make your tires smoke just doesnt make good sense. My snow blower can sit and smoke its tires.If i let it sit in front of a wall and put it in drive and smokem.
(Post 1583129872)
I knew what you meant. It was just a good excuse for me to post that picture again.
:thumbs: |
