Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-06-2013, 11:55 PM   #1
vetteguy75
CF Senior Member
LA Events Coordinator
Support Corvetteforum!
vetteguy75's Avatar
Default Not that I plan to do this but....How do you do a burn-out?
I'm not planning to do a burn-out, but how, logistically, do you do it? I understand that you have to keep one foot on the brakes and the other on the accelerator....If you do that won't that ruin your rear brakes? I've always wondered..... Funny, whenever I stomp on my accelerator from a stand-still, I just get pure acceleration...no squeal or tire burning...just GO!
vetteguy75 is offline   Reply With Quote
Old 02-07-2013, 12:08 AM   #2
bluedawg
CF Senior Member
It wont ruin the rear brakes unless you do it all the time. This method is referred to power breaking. If you have enough power you can do it by just stomping the accelerator.
bluedawg is offline   Reply With Quote
Old 02-07-2013, 12:11 AM   #3
Oldguard 7
CF Senior Member
Oldguard 7's Avatar
That is how you do it if you don't have a line lock installed. As you probably already know the purpose drag racers do a burn out is to warm up the tires so they stick to the track. The white smoke you see is aided by a water/bleach mixture. Hope I didn't go off on a tangent or insulted your intelligence. But that's the way you do it as you wrote in your post. You have to really keep your foot on the brake pedal while spinning your wheels. If you have some seroius hp you will get a good amount of smoke.
Oldguard 7 is offline   Reply With Quote
Old 02-07-2013, 12:11 AM   #4
MrJlr
CF Senior Member
MrJlr's Avatar
What you are talking about is "power braking".....only use the minimum brake presure possible....yes....it's always hard on your car......but fun!
My car smokes the tires without power braking......
Find a parking lot with no one around...be safe and do it once.....it's a freakin Corvette for God's sake!!!!!!!!!!!!!!
Be safe
MrJlr is offline   Reply With Quote
Old 02-07-2013, 12:21 AM   #5
gkull
CF Senior Member
gkull's Avatar
You have lived a sheltered life or else you have only owned sorry *** slow vehicles
To do a smokey burn out on my bike without the brake I rev it to 8000 rpm and drop the clutch. Your car doesn't do 14,000 rpm so only rev it to about 4000 in "N" and then drop it into drive with your foot on the floor.
Guarantied that it will burn your tires at least for a few times.
gkull is offline   Reply With Quote
Old 02-07-2013, 01:09 AM   #6
TimAT
CF Senior Member
TimAT's Avatar
Or there will be a loud very expensive noise.
TimAT is offline   Reply With Quote
Old 02-07-2013, 01:13 AM   #7
my_z
CF Member
Quote:
my_z is offline   Reply With Quote
Old 02-07-2013, 01:30 AM   #8
cuisinartvette
CF Senior Member
St. Jude Donor '05
Thats the goal! Burnouts are for kids never understood the significance of them
cuisinartvette is offline   Reply With Quote
Old 02-07-2013, 01:37 AM   #9
SuperBuickGuy
CF Senior Member
SuperBuickGuy's Avatar
it's rarely the noise that's expensive .... unless, of course, it's the one emanating from one's spouse
SuperBuickGuy is offline   Reply With Quote
Old 02-07-2013, 02:29 AM   #10
Bangkok Dean
CF Senior Member
Bangkok Dean's Avatar
I have tried it a couple of times with my 5 speed manual, all I get is big time wheel hop after dropping the clutch. Now if I start moving and stomp on it the wheels will spin.
Bangkok Dean is offline   Reply With Quote
Old 02-07-2013, 06:29 AM   #11
Matt Gruber
CF Senior Member
Back in HS the Auto shop students would get to park the drivers Ed cars back up real fast, keep it floored, then shift to Drive while doing ~30mph in reverse lots of smoke until teacher came out and complained.
Matt Gruber is offline   Reply With Quote
Old 02-07-2013, 07:10 AM   #12
racerbug
Junior Member
Try putting water under the rear wheels,then try power braking it.Rev it up in neutral and put in gear will only break u-joints or inner axles.Don't ask how I no.
racerbug is offline   Reply With Quote
Old 02-07-2013, 07:31 AM   #13
Pelee4me
CF Member
Pelee4me's Avatar
Turn off the traction control before you do anything. When I first tried a full throttle start in my C6 I expected some smoke.... I got nothing. Then I remembered the traction control, turned that off and tried again... lots of smoke and squealing.
Pelee4me is offline   Reply With Quote
Old 02-07-2013, 07:56 AM   #14
ezobens
CF Senior Member
Be safe
I must be old-
Back when I was a kid (now I sound like my grandfather), the term we used was "Brake-Torque"...
Maybe that was just a mid-70's Midwestern term?
Anyway, the method was used for automatic powered cars that couldn't break them loose otherwise. To make it easier to perform, we'd do it over a manhole cover or at the leading edge of a speed bump..
For really power challenged vehicles, we employed a technique affectionately called the "Brinni-Drop", named after a friend of ours that devised the technique (to our knowledge anyway).
To perform this technique, you put the car in reverse, floor it and when you reach about 10mph or so in reverse, you dump the trans into low gear (all the while keeping your right foot firmly planted to the firewall).
You could get some spectacular results from cars that could normally never spin their tires.
This was much more painful on the drivetrain but in high-school, who cared?
Besides, we usually did it in our parent's cars so it didn't matter..
Surprisingly enough, we never dropped a trans or a driveshaft with this technique.
Ahh.. The good ole' days....
Have fun!
ezobens is offline   Reply With Quote
Old 02-07-2013, 08:10 AM   #15
Hameister
CF Senior Member
Hameister's Avatar
Location: South Florida 'Vette Season is 365 days a year!
I guess I must be getting old. Burnouts are necessary, in the staging area of a drag strip.
For street operation, it seems to me, it's nothing more than a macho, "look at me", exercise.
Which would be just fine, if you didn't leave $800.00 worth of rubber in the street.
Hameister is offline   Reply With Quote
Old 02-07-2013, 08:21 AM   #16
ezobens
CF Senior Member
Lighten up Frances jk
When we were kids, it had nothing to do with being 'Macho' and we normally did it where we wouldn't be seen or get caught.
Some of us just like the smell of burning rubber and still do
If you're burning up $800 in tires, your doing it wrong-
We used to by used tires from Sears or JC Penny auto centers for $5-$10 bucks a piece (back in the 70's and 80's remember) for the sole purpose of smoking them off.
Even today, the kid in me snickers when I light em' up by "accident"..
As an old friend told me years ago.. "These cars were meant to get-on".
Old 02-07-2013, 08:29 AM   #17
Hameister
CF Senior Member
Hameister's Avatar
Well, to each his own my friend. As a kid, I had a GTX 440 6 PAK 435hp that ran SS-E. My friends all had muscle cars as well, and we all raced at the local drag strip, nearly every Sunday. That's where we tore up street tires, or slicks. No one burned up rubber in the street. We were all well aware that it was potentially dangerous, and a waste of money. But, like I said, to each his own.
Frances
Old 02-07-2013, 08:37 AM   #18
daanbc
CF Senior Member
St. Jude Donor '12
daanbc's Avatar
As a kid I had a 81 TRANS AM with the lam 4.9 "301" motor. I placed BF Goodrich tires on back. But what made it worst was they were 50's. So damn wide and to much traction. So I took my windshield washer hose that went to my wipers, spliced and routed them to the top of the rear wheel fenders. Then filled the wiper bottle with bleach n water. I would spray the tires so they would be soft, then I was able to smoke'em. Fun in High school. But tires get expensive. LOL.
daanbc is offline   Reply With Quote
Old 02-07-2013, 08:47 AM   #19
hugie82
CF Senior Member
With a stock 75 vette doing a burnout??? You better invest in a line lock system or plan on an engine up grade
hugie82 is offline   Reply With Quote
Old 02-07-2013, 09:05 AM   #20
7t9l82
CF Senior Member
7t9l82's Avatar
im working on keeping mine from going up in smoke, no I'm not gonna pull out 2 spark plugs. I've never had a car that i had to power brake to spin em. i would advise against neutral drive drops.......... lighten up francis, l.o.l. from stripes good one
7t9l82 is offline   Reply With Quote
Reload this Page Not that I plan to do this but....How do you do a burn-out?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
