Bought mine from Gene. Great price and tightens up the turns. Repainted mine Le Mans (Luxo) Blue. Gene is ffast shipment, too.
I have an 04 and there is no problem, simple bolt on upgrade. What a difference. The 04 had the same metal end links as Gene sells. |
Originally Posted by stevegray04
(Post 1583057722)
Gene: So if I change to the Z51 bars, do I have to worry about rubbing or not? If so, is there a fix? I have read good things about this, but I don't want to do this supposedly straight-up, bolt-on upgrade and then have a problem. I have an '04.
(Post 1583057722)
Originally Posted by kenc5
(Post 1583057942)
I installed the C6 Z51 sways on my 2001 C5, and I swear that the car sits about an inch higher than it did before. I did not change the shocks as I have the F45 shocks with only 16,000 miles on them. Will upgrade to C6 Z06 shocks when they wear out. I noticed it right away in the gap above the tires. Anyone else seen this? Will it settle back down to normal ride height over time.?
Thanks, Phil |
Originally Posted by phil hunter
(Post 1583139983)
Thanks, Phil |
(Post 1583057942)
Unless they are damaged, you would not have to replace the metal end links you alrerady have.
Phil |
(Post 1583145126)
Phil |
According to Gene's link, the difference between the C6Z51 and C6Z06 sway bars is the rear bar diameter; 25.4mm vs 28.0mm. Is the Z06 bar considered too large/stiff for the balance? I have a C5Z06 and am pretty much set on the C6Z06 shocks. Just wondering about the C6Z06 vs C6Z51 sway bars. Good info everyone...thanks!
