C6 Z51 sway bars on C5
As long as you do nohting more than replace them, it should not effect the alignment.
If you take off any of the 'a' arms at the wheels, you'll then need an aliignment. |
Originally Posted by fishbust
(Post 1583010002)
Kool, thanks Phanni.
Now I just have to find the best price shipped and with the updated end links. Ready to drop the hammer! :cool: |
The C6 Z51 sway bars will be a nice upgrade to your car.
I would certainly be happy to help you out with that kit. Please click on my C5 suspension upgrade sale thread.
http://forums.corvetteforum.com/c5-g...house-com.html |
I bought mine along with the C-6 Z06 shocks from Gene a couple of years ago. Best low dollar upgrade avaiable.
Gene is the man and he'll do whatever it takes to point you in the right direction:thumbs:
Jim:flag: |
I got mine from Gene as well. Word of warning. My sways rubbed on my cradle. The cradle steps out a tiny bit just outside of the bushing mounts. The fatter C6 Z51 swaybar rubbed in those locations. I made a pair of shims to step the bushings/sways off the cradle to clear those spots so it doesn't rub anymore. I know others have had the same problem so keep an eye on it.
Best all around bars for a C5 that do not run 325s or wider tires:rock:
Thank you all for your business and the kind words. :thumbs:
Originally Posted by peter pan
(Post 1583025655)
I have the C6Z51 sways and I run a 345/25/20 which I track from time to time with no issue at all or any rubbing |
(Post 1583025655)
Originally Posted by vetfeva2
(Post 1583054723)
HUH????
I have the C6Z sways and I run a 345/25/20 which I track from time to time with no issue at all |
(Post 1583054723)
HUH????
Originally Posted by jcsperson
(Post 1583054779)
Yeah, but the OP asked about C6 Z51 sway bars. They're a bit thinner than the Z06 sways and recommended for a narrower tire.
(Post 1583054798)
So would the C6 Z06 been a better choice?
I put the C6 ZO6 shocks and sways on mine and I Love them..!
Gene: So if I change to the Z51 bars, do I have to worry about rubbing or not? If so, is there a fix? I have read good things about this, but I don't want to do this supposedly straight-up, bolt-on upgrade and then have a problem. I have an '04.
