1968 radiator support info
have a late nov or early dec 1968 350hp 350cu inch car, took it apart years ago, now kind of going thru things to sell, the radiator support has the big block upper tin part that directs air thru the hood, not small block, had the big block radiator, but no air conditioning, just a base 350hp, now the strange part, it has all the holes for a big block support, including holes to bolt the big block shroud, but on the bottom where the radiator is supported, it has both big block lower support, (two arms sticking out to hold the radiator) and the small block lower supports for the aluminum small radiator, any one seen anything like this? it is factory not glued together.
I'm not sure what you've found. It sounds like a big block fan shroud could be been installed on the smallblock radiator support.
Pics might help. :thumbs: |
