Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-26-2013, 09:11 AM   #1
popbluff
CF Senior Member
Default 1968 radiator support info
have a late nov or early dec 1968 350hp 350cu inch car, took it apart years ago, now kind of going thru things to sell, the radiator support has the big block upper tin part that directs air thru the hood, not small block, had the big block radiator, but no air conditioning, just a base 350hp, now the strange part, it has all the holes for a big block support, including holes to bolt the big block shroud, but on the bottom where the radiator is supported, it has both big block lower support, (two arms sticking out to hold the radiator) and the small block lower supports for the aluminum small radiator, any one seen anything like this? it is factory not glued together.
popbluff is offline   Reply With Quote
Old 01-26-2013, 10:54 AM   #2
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
I'm not sure what you've found. It sounds like a big block fan shroud could be been installed on the smallblock radiator support.
Pics might help.
Easy Mike is offline   Reply With Quote
Reload this Page 1968 radiator support info
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
