Originally Posted by theradioflyer
(Post 1582942220)
I believe England is exclusive in requiring rear fog lights and side repeater turn signals.
The T-84 is the generic E-code headlight for export vehicles. IIRC all export cars (euro or not) got the E-code headlights. . I'll try to dig out the reference. |
European Union Regs on Fog Lights
This level of inspection requires documentary evidence to prove compliance with European Community Directives for up to 12 key areas as listed in the Normal IVA General requirements section. Compliance with alternative standards is acceptable where specified.
Rear Fog Lamp. Min 1 Max 2 . Mandatory. Red, At least one must be on centre line or to offside of vehicle (Min separation distance from stop lamp 100mm) . Max Height: 1000mm. Min Height 250mm. Angles of Visibility: a. Horizontal i. 250 degrees inwards and outwards; if two lamps are fitted it is sufficient if one lamp (not necessarily the same lamp) – is visible throughout the range b. Vertical i. 5 degrees above and below horizontal. |
Side Marker Lamps
Side Marker Lamp.
Mandatory Where the length exceeds 6m Amber The rearmost marker may be red if within 1m of rear Max Height 1500mm or if impracticable 2300mm Min Height 250mm Angles of Visibility: a. Horizontal i. 45° to the front and rear (Can be reduced to 30° if fitted as an optional extra) b. Vertical i. 10° Above and below the horizontal (The vertical angle below the horizontal may be reduced to 5° if the side marker lamp is fitted less than 750mm from the ground. |
DRLs
A Daytime Running Lamp must be white.
Pull the A2 fuse of do the relay mod:thumbs: |
Do you think I had to convert a C5 to comply with EU regulations
:rofl::rofl::rofl::rofl::rofl: |
Germany has something called the TUV-their version of DOT/NHTSA. Germans are so demanding in this regard, that any aftermarket accessory that could effect safety-wheels for example-must have a TUV approval number (meaning it's been tested). Try Googling them-maybe they have guidelines for importation and conversion. Regarding headlight washers, don't have an answer on requirements. I do know my '85 M635CSi (grey market) have washers AND little wiper blades to clean the surfaces of the lights-so that concept has been around before HID.
Australia also require side turn signals placed no further back than 1500mm front the front, so here you see them near the fender cove.
Must also be (E) marked Amber indicators Headlights must dip to the left (E) marked |
Originally Posted by PhilsFRC
(Post 1582944670)
Germany has something called the TUV-their version of DOT/NHTSA. Germans are so demanding in this regard...
Some feedback would be good FastlaneMech
Jochen may also help: http://forums.corvetteforum.com/c5-t...e-the-drl.html |
Just curious where Italy falls in the all these regulations? I plan on getting a home there end of this decade, spending half the year exploring Europe with that as our base (Northern Italy) and hope to take a ZR1 or something over there.
You might try to get hold of the Velumen company in Germany. They made these lower opening projector headlights for the German Corvette market and now you can get them in the U.S. I think they must have been certified for sale in Germany. I don;'t have a German contact or address, but with some sleuthing you might find them. Similar to the Sun Guns sold on this site, but unlike the Sun guns, the Velumens actually have headlight shrouds.
http://www.c5racer.com/catalog/c5-c6...ht-system.html |
Originally Posted by JETninja
(Post 1582959463)
Originally Posted by jornahow
(Post 1582959958)
I found some cool lights when I was modifying my car but played safe and bought the GM kit that I knew would pass the inspection. |
Originally Posted by DeeGee
(Post 1582960170)
Over here, we're all part of the EU. EU regulations apply to the whole of Europe. Some countries are strict; others lenient. I'll let you guess where Italy sits.
Of course, the ways things are who knows if Spain, Greece and Italy will still be a part of the EU 7 years from now! |
(Post 1582960220)
They might work but imagine getting to the safety inspection and the inspectors says "Nein". At least T84s are E marked.
I found some cool lights when I was modifying my car but played safe and bought the GM kit that I knew would pass the inspection. Just quick question on headlights, In UK are we able to fit the projector HID upgrades, halo Mods etc? :( |
Originally Posted by Brit dex
(Post 1582961307)
Dee Gee
Well, I have the DEPO projector headlights that gives it a C6 look. Does the T85 bulb fit into the projector set?
i mean T84
No the T84/T85 uses a standard H4 dual filament bulb.
(Post 1582967971)
If your car is through SVA/IVA its down to your MOT inspector. Officially everything has to be E Marked. Most MOT guys don't mind if it passes the MOT test regime.
only been out at night a couple of times, but the lights aren't the brightest!!!:eek: really fancied some of the deals on the updates for projectors and halos... done LED's on the rears and indicators and they are great.. |
