Originally Posted by rad928music
(Post 1582494188)
I see allot of Older guys driving those Hemi Challengers.
Corvette will never be "Old mans car" to people who really understand and drive Vettes IMO. Yes there maybe some older guys driving them but they are not old @ heart :thumbs: .......I was thinking about a C6 but the C7 was around the corner and I knew I would be kicking myself later if I pulled that C6 trigger :) |
The NPP..The zl1 has a system that opens at idle. That is when you are sitting at a light or sitting in a parking place the system does its by-pass thing. That makes the idle nasty. Then when you drive away it quiets down until you nail it. Then it works like the C6 system. My bet is the C7 will do the same hint. From what I have read the middle two pipes are by-passers and the out side pipes are the quiet (relatively) outlets.
:cheers: |
Originally Posted by keeks2915
(Post 1582494162)
There are a handful near Novi, Mi right now.
With the right swipe card and retinal scan you are good to go. |
Originally Posted by 1analguy
(Post 1582493977)
"Hypereutectic" refers to the thermodynamic characteristics of the specific alloy, not to its method of manufacture (cast vs forged, etc.)...
While it's possible to forge or cast a wide variety of alloys, some are better for casting while others are better for forging. For forging, you want an alloy with a grain structure that "flows" or aligns more readily during the forging process. If correctly done, this results in a stronger piston because the grain structure will be aligned along the load paths. Unfortunately, many forge-able alloys have a higher coefficient of expansion (partially because the forging process results in a denser grain structure...there's just more aluminum packed into a given volume) than the preferred casting alloys do, so they grow and change shape more when going from cold to operating temperature than the "casting alloys" do. Forged pistons are stronger, but their greater expansion when heating requires greater bore clearances when cold. Those greater cold clearances have the potential to negatively affect ring seal just when cold engine emissions are beginning to come under scrutiny. Modern cast pistons are much more dimensionally stable and so can be run with much tighter clearances. If less-than-forged strength will suffice, engineers will choose cast jugs every time. There is too much upside to doing so for them to ignore all the benefits of those tighter clearances, not to mention the lower cost. When spread over thousands (or even millions) of engines, that's a real consideration, too...
Originally Posted by Hemi Dave
(Post 1582492018)
LOL...
I could have had a Vette already but I aint that old and I wanted to wait for the C7.....you know...for the younger generation :) .....and it's only common sense that the C7 WILL outperform the C6. You really think Chevy is gonna screw up on the HALO car???? .......Give me a break...NOT gonna happen ...The C6 was better than the C5 and the C7 will be no different... ....I dont even have to wait until Jan 13, 2013 to know that.... ...I dont need to own a Vette to know that either.... ... My deposit on my C7 has already been placed.....thats how SURE I am |
Originally Posted by RocketGuy3
(Post 1582500598)
Of course it will be faster than a C6. The question is how much faster...
(Post 1582500598)
After reading the whole Hot Rod article and some of the other articles put out that indicate GM is attempting to prevent the ECM from being reflashed, my suspicion is that GM will offer it's own Stage One/Stage Two type reflashes that will bump up the horsepower significantly beyond the 450 mark, and will retain your warranty.
This will allow GM to be able to tap into the money that used to go to the aftermarket for tuning and modification. |
Originally Posted by CSixDude
(Post 1582501826)
(Post 1582501826)
(Post 1582501826)
Originally Posted by jbomx363
(Post 1582503309)
Highly doubtful.
If I read the Hot Rod article correct, GM is already doing this with some of their V6 Engines. So it isn't too far out of the realm of possibilities. From what I've also read, it appears GM has put some pretty serious encryption algorithms into the new ECM as well to try to prevent it from being reflashed by anyone except a GM dealership. It might also explain the "snicker" that the GM Engineers had over the announced 450 HP number. Yea, its 450 hp in stock trim, but with the turn of a couple electronic dials it can climb close to Z06 territory. It would seem like a smart marketing move on GM's part, but I guess we'll have to wait and see. |
Originally Posted by I Bin Therbefor
(Post 1582490457)
Someone needs to start a two question survey.
Will the BASE C7 have more than 450HP? Yes or No Will the BASE C7 weigh less than 3000 lbs? Yes or No A little more (under 3100 would be amazing in a modern sports car. I don't think it's feasable to do under 3000.) :thumbs: |
(Post 1582503537)
Maybe. But I can certainly envision a scenario where GM releases a base model car with around 450hp, but you can pay the dealer a fee ($1,000 or so?) to have it upgraded via a reflash and maybe another performance part or two added (CAI) that will increase it to nearly 500hp but still retain your factory warranty.
If I read the Hot Rod article correct, GM is already doing this with some of their V6 Engines. So it isn't too far out of the realm of possibilities. From what I've also read, it appears GM has put some pretty serious encryption algorithms into the new ECM as well to try to prevent it from being reflashed by anyone except a GM dealership. It might also explain the "snicker" that the GM Engineers had over the announced 450 HP number. Yea, its 450 hp in stock trim, but with the turn of a couple electronic dials it can climb close to Z06 territory. It would seem like a smart marketing move on GM's part, but I guess we'll have to wait and see. A reflash for more power is much easier with a boosted car where you can raise the boost pressure though, so I also think it seems less likely with the LT1. |
Originally Posted by CPhelps
(Post 1582505198)
I don't think GM is doing this with any of their V6 engines. They did do it with the Cobalt SS/TC, Saturn Sky RedLine, and Solstice GXP 2.0L turbo SIDI "LNF" engine, though. Stock output was 260hp/260tq but with the GM dealer installed upgrade, the numbers were boosted to 290hp/340tq with retained factory warranty.
Wonder if Chuck Cow could break the ECM................:yesnod:
Just sayin' Mike :canadaflag: |
Originally Posted by rcallen484
(Post 1582505219)
How much did they charge for that?
EDIT: Google search returned some additional reading: http://www.gmpartshouse.com/19212670...bo-upgrade-kit http://www.motorauthority.com/news/1...lstice-sky-hhr Looks like GM Parts house has it for 500, but the original article cited 650. That article is particularly interesting as it mentions unlocking an ECU "learning feature", "enables the computer to adapt to and benefit from basic bolt-on mods such as intakes and exhausts." I've never done any research to see how effective that actually was. The article also reminded me that part of the tune raised the redline. |
Thanks for the post interesting read and I will be wanting a new C7 in the future.
Don't get too excited.....yet.
Originally Posted by mracer
(Post 1582505545)
Just sayin' Mike :canadaflag: Don't get too excited.....yet. This is the new E92 pcm from the 2013 C7 LT1 CORVETTE. http://www.corvettes-of-westchester....huck%20CoW.png We already know that it's much more complicated than the C6 PCMs due to the direct injection and it's other potentials features, but beyond that.....We anticipate that it's gonna be a "HARDER NUT TO CRACK". Don't expect to roll this one off the showroom floor and right into your favorite tuner's shop.... It could be a while before that's possible....:ack: Below is the new Direct Injection FUEL RAIL AND INJECTORS. http://www.corvettes-of-westchester....huck%20CoW.png It's got a mechanical jack pump that rides the cam to make CRAZY fuel pressure and what looks like a piezo electric type regulator. Very much like a conventional diesel. This new car does not make that much more horsepower than the C6, but it sure will cost you a good bit more.:D Stay TUNED for more information from..... Chuck CoW |
