C6 Z06 brake upgrade
Wow....
After spending a day with ZR-1 brothers in Virginia, we installed a few items: 32mm sway bar new A arms (with new bushings / ball joints) *polished up too!! new front hubs C6 Z06 calipers / 1 piece ceramic brake pads / stock Z06 rotors There is a huge difference, even with Ceramic pads! Going to install the rear brake calipers / rotors in the coming week. (can't wait!!!) Thanks to Yun, Gibby, Mark, Matthew ***(new to most), Paul, Mike **(new), Glen and especialy Rich for hosting this!!!!! Lots of pictures and will document the C6 Z06 brake upgrade for the newsletter. You do need larger wheels in order to accomodate the large 6 piston front calipers and 4 piston rear.... WORTH IT! For asthetics and stopping power Here is a teaser http://i160.photobucket.com/albums/t...l/ff400875.jpg http://i160.photobucket.com/albums/t...l/4a8fe255.jpg :cheers: David * thanks Rich!!!! ** Welcome to Wazoo Mike!!! (he is setting up a C4 ZR-1 road race car) *** Newest Admiral Blue ZR-1 owner! |
Very nice and looks great!
I agree!
http://i529.photobucket.com/albums/d...-Brakes812.jpg I haven't done the rears because I want to keep the parking brake, and I don't want to have to buy/install different backing plates. What is your plan? And I can toss my spare. Won't work/fit. I have a can of slime and a patch kit. I will just hope I don't get a flat. Do you know of a spare that will work? Good Luck! PS: Wow, we both installed our "Fikse" center caps upside down! JK PSS: I'm jealous you did it all in a day. I spent A LONG time first getting the caliper adapter bracket right, then fighting with sizing a new braided SS brake line. Wish I was near a group like WAZOO, TEXAS, or FBI! Figures, right after I post, I see your first picture. Much better shot, and mine is the same set up. |
Originally Posted by 95ZR1
(Post 1581496474)
I agree!
http://i529.photobucket.com/albums/d...-Brakes812.jpg I haven't done the rears because I want to keep the parking brake, and I don't want to have to buy/install different backing plates. What is your plan? And I can toss my spare. Won't work/fit. I have a can of slime and a patch kit. I will just hope I don't get a flat. Do you know of a spare that will work? Good Luck! PS: Wow, we both installed our "Fikse" center caps upside down! JK Figures, right after I post, I see your first picture. Much better shot, and mine is the same set up. http://i45.tinypic.com/11wawk1.jpg |
Originally Posted by Vette Daddy
(Post 1581496553)
Will the late model GTO spare work with the C6 calipers??? It works with the C5 calipers. The Fikse shown also works with C5 clipers.
http://i45.tinypic.com/11wawk1.jpg I would look for the 18" CTS spare tire- they are rumored to fit these late model brakes. btw, the brake pad for the regular C6 caliper and the C5 are the same part. the caliper is a little different on the C6, but it uses the same pad so I don't see why one would bother when the C5 stuff fits on the C4's without too much trouble. Now the Z06 6-pot calipers are a different story entirely. Big difference i'm sure. |
Thanks, Mike. :cheers: I was just wondering for these guys' sake. I plan on keeping my 17" Dymags on my Turq Z.
Maybe install the C6 ZR-1 brake setup on my next Z and run bigger wheels????/ |
Originally Posted by mike100
(Post 1581496631)
My wheels are 18", so I don't think the GTO will fit. |
(Post 1581496474)
I agree!
http://i529.photobucket.com/albums/d...-Brakes812.jpg I haven't done the rears because I want to keep the parking brake, and I don't want to have to buy/install different backing plates. What is your plan? And I can toss my spare. Won't work/fit. I have a can of slime and a patch kit. I will just hope I don't get a flat. Do you know of a spare that will work? . Spare? I'm calling a AAA for a flat bed! :thumbs: :cheers: David |
(Post 1581496474)
I agree!
brake upgrade
Any suggestions to upgrade stock brakes on 2007 z06?
18's or 19's?
Originally Posted by nick giampetro
(Post 1584257592)
http://i187.photobucket.com/albums/x...Drove003-1.jpg |
Does anyone make the brackets for the front/rear to bolt on? What rotors are used/sizes? I was planning to take the Baer setup I have for my 93 and use it on the Z but may look into doing this instead. The new wheels I am building show a LOT of brake and insides so I def need a better brake setup asap.
Hell with the ebrake :rock: |
there was a guy that was selling the brackets in the forsale section and I saw some on eBay
the front is just the c4 to c5/c6 bracket as I recall.. not sure about the rear |
brake upgrade
I have a 2007 z06 with 18 and 19s - any suggestions?
Brackets available on eBay. The C5/C6 adapters need a slight modification for the Z06 brakes. Need C6 Z brake lines. With the Z06 rotors I can use the Z06 wheel offset and be very close to stock tire/wheel clearance.
Your spare will be useless. You will need a 2008-2011 Cadillac
CTS 18"spare and a (min) 3/4" adapter or spacer. Then try and get it to fit in the spare tire carrier- tight! Thanks WVZ! This is for a C6 Z06 caliper only |
(Post 1584264850)
(Post 1584260746)
Originally Posted by Dominic Sorresso
(Post 1584267596)
Have u test fit this? I was told CTS 18" wouldn't work. The other question I have is whether our stock spare would work w a spacer thick enough to clear the C6Z calipers?
and clears a C6 Z06 caliper WITH AN ADAPTER/SPACER |
