Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-05-2012, 07:44 PM   #1
LT5corsa
1994 Admiral Blue ZZZZZR1
Northeast Events Coordinator
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Support Corvetteforum!
LT5corsa's Avatar
Default C6 Z06 brake upgrade
Wow....
After spending a day with ZR-1 brothers in Virginia, we installed a few items:
32mm sway bar
new A arms (with new bushings / ball joints) *polished up too!!
new front hubs
C6 Z06 calipers / 1 piece ceramic brake pads / stock Z06 rotors
There is a huge difference, even with Ceramic pads!
Going to install the rear brake calipers / rotors in the coming week. (can't wait!!!)
Thanks to Yun, Gibby, Mark, Matthew ***(new to most), Paul, Mike **(new), Glen and especialy Rich for hosting this!!!!!
Lots of pictures and will document the C6 Z06 brake upgrade for the newsletter.
You do need larger wheels in order to accomodate the large 6 piston front calipers and 4 piston rear.... WORTH IT!
For asthetics and stopping power
Here is a teaser
Click the image to open in full size.
David
* thanks Rich!!!!
** Welcome to Wazoo Mike!!! (he is setting up a C4 ZR-1 road race car)
*** Newest Admiral Blue ZR-1 owner!
LT5corsa is offline   Reply With Quote
Old 08-05-2012, 08:42 PM   #2
cal55
CF Senior Member
cal55's Avatar
Very nice and looks great!
cal55 is offline   Reply With Quote
Old 08-05-2012, 09:55 PM   #3
95ZR1
CF Senior Member
95ZR1's Avatar
I agree!
I haven't done the rears because I want to keep the parking brake,
and I don't want to have to buy/install different backing plates.
What is your plan?
And I can toss my spare. Won't work/fit. I have a can of slime and a
patch kit. I will just hope I don't get a flat. Do you know of a spare
that will work?
Good Luck!
PS: Wow, we both installed our "Fikse" center caps upside down! JK
PSS: I'm jealous you did it all in a day. I spent A LONG time first getting
the caliper adapter bracket right, then fighting with sizing a new braided
SS brake line. Wish I was near a group like WAZOO, TEXAS, or FBI!
Figures, right after I post, I see your first picture. Much better shot,
and mine is the same set up.
95ZR1 is offline   Reply With Quote
Old 08-05-2012, 10:05 PM   #4
Vette Daddy
CF Senior Member
Vette Daddy's Avatar
Quote:
Originally Posted by 95ZR1 View Post
I agree!
What is your plan?
that will work?
Good Luck!
JK
Will the late model GTO spare work with the C6 calipers??? It works with the C5 calipers. The Fikse shown also works with C5 clipers.
Vette Daddy is offline   Reply With Quote
Old 08-05-2012, 10:15 PM   #5
mike100
CF Senior Member
mike100's Avatar
That GTO spare won't fit on my '08 C6 without a spacer, but I have the slightly larger Z51 rotors. I have heard it will fit over the base coupe C6 brakes since they are about the same size as c5 brakes.
I would look for the 18" CTS spare tire- they are rumored to fit these late model brakes.
btw, the brake pad for the regular C6 caliper and the C5 are the same part. the caliper is a little different on the C6, but it uses the same pad so I don't see why one would bother when the C5 stuff fits on the C4's without too much trouble. Now the Z06 6-pot calipers are a different story entirely. Big difference i'm sure.
mike100 is offline   Reply With Quote
Old 08-05-2012, 10:23 PM   #6
Vette Daddy
CF Senior Member
Thanks, Mike. I was just wondering for these guys' sake. I plan on keeping my 17" Dymags on my Turq Z.
Maybe install the C6 ZR-1 brake setup on my next Z and run bigger wheels????/
Old 08-05-2012, 10:24 PM   #7
95ZR1
CF Senior Member
95ZR1's Avatar
Quote:
Right, and I BELIEVE the front rotors (C6 Z06) are larger at 14".
My wheels are 18", so I don't think the GTO will fit.
Old 08-06-2012, 06:49 AM   #8
LT5corsa
LT5corsa's Avatar
I agree!
What is your plan?
that will work?
E brake plan? None for now, I never use it. (this kit can connect to a line lock to the rear, but passed on it)
Spare? I'm calling a AAA for a flat bed!
David
Old 08-06-2012, 11:50 PM   #9
rickyrj1
CF Senior Member
rickyrj1's Avatar
I agree!
What is your plan?
that will work?
Good Luck!
Your going to have to convert to a hub style E-brake for the rears or have a 2nd small rear cal. like on Wilwood/DRM set up. I beleive the 2nd option was limited because the thickness of the Zo6 rotors. GL
rickyrj1 is offline   Reply With Quote
Old 06-26-2013, 08:33 PM   #10
nick giampetro
Junior Member
Default brake upgrade
Any suggestions to upgrade stock brakes on 2007 z06?
nick giampetro is offline   Reply With Quote
Old 06-26-2013, 10:43 PM   #11
USAFPILOT
CF Senior Member
USAFPILOT's Avatar
18's or 19's?
USAFPILOT is offline   Reply With Quote
Old 06-26-2013, 10:59 PM   #12
Dominic Sorresso
CF Senior Member
Dominic Sorresso's Avatar
Send a message via AIM to Dominic Sorresso
Quote:
My suggestion is to do it. You need 18" wheels for the front.
Dominic Sorresso is offline   Reply With Quote
Old 06-27-2013, 03:21 AM   #13
5abivt
CF Senior Member
5abivt's Avatar
Does anyone make the brackets for the front/rear to bolt on? What rotors are used/sizes? I was planning to take the Baer setup I have for my 93 and use it on the Z but may look into doing this instead. The new wheels I am building show a LOT of brake and insides so I def need a better brake setup asap.
Hell with the ebrake
5abivt is offline   Reply With Quote
Old 06-27-2013, 08:16 AM   #14
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
there was a guy that was selling the brackets in the forsale section and I saw some on eBay
the front is just the c4 to c5/c6 bracket as I recall.. not sure about the rear
-=Jeff=- is offline   Reply With Quote
Old 06-27-2013, 08:45 AM   #15
nick giampetro
Junior Member
I have a 2007 z06 with 18 and 19s - any suggestions?
Old 06-27-2013, 08:56 AM   #16
Dominic Sorresso
CF Senior Member
Brackets available on eBay. The C5/C6 adapters need a slight modification for the Z06 brakes. Need C6 Z brake lines. With the Z06 rotors I can use the Z06 wheel offset and be very close to stock tire/wheel clearance.
Old 06-27-2013, 04:25 PM   #17
95ZR1
CF Senior Member
95ZR1's Avatar
Your spare will be useless. You will need a 2008-2011 Cadillac
CTS 18"spare and a (min) 3/4" adapter or spacer. Then
try and get it to fit in the spare tire carrier- tight!
Thanks WVZ!
This is for a C6 Z06 caliper only
Old 06-27-2013, 09:43 PM   #18
Dominic Sorresso
CF Senior Member
Thanks WVZ!
Have u test fit this? I was told CTS 18" wouldn't work. The other question I have is whether our stock spare would work w a spacer thick enough to clear the C6Z calipers?
Old 06-27-2013, 10:02 PM   #19
combatdoc
CF Senior Member
combatdoc's Avatar
my buddy just upgraded pads and rotors on his c6 Zo6 carbon ceramaic
combatdoc is offline   Reply With Quote
Old 06-28-2013, 02:09 AM   #20
95ZR1
CF Senior Member
95ZR1's Avatar
Quote:
This is the set-up I have on my Z. The 18" CTS donut spare fits
and clears a C6 Z06 caliper WITH AN ADAPTER/SPACER
Reload this Page C6 Z06 brake upgrade
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ECM from 1995 ZR-1 (FS) LT5corsa C4 Parts for Sale/Wanted 1 10-30-2013 09:56 PM
C5/C6 brake upgrade (new adapters included) LT5corsa C4 Parts for Sale/Wanted 3 08-18-2012 01:50 PM
J55 calipers off a ZR-1 (great upgrade) LT5corsa C4 Parts for Sale/Wanted 1 08-11-2012 10:38 PM
Newly powder coated C6 calipers / new hawk ceramic pads LT5corsa C6 Parts for Sale/Wanted 1 07-29-2012 06:46 PM
Perfect track wheels (OEM ZR-1 rear wheels) LT5corsa C6 Parts for Sale/Wanted 10 07-25-2012 09:25 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
